Results 1 to 2 of 2
  1. #1
    Gold Member
    Join Date
    Jan 2011
    Posts
    290
    Queensland Australia
    Kioti DS4510HS , Kubota B7100
    Default B7100 3 pt hitch slowly losing pressure
    The 3 pt hitch on my B7100D (gear) will lift my brush hog for awhile but slowly loses pressure and lowers the implement so that I have to raise it again with the control lever.
    The problem has been getting slowly worse over time.
    My understanding is that the possible reasons are:
    1. A worn oil pressure piston O ring, piston or cylinder.
    2. Faulty control valve
    3. Faulty spool
    Has anyone undertaken an overhaul of the hydraulic lift system and could you advise of the most likely cause and how you approached the overhaul.
  2. #2
    Join Date
    Oct 2005
    Posts
    931
    New Hampshire, USA
    Kubota B6100
    Default Re: B7100 3 pt hitch slowly losing pressure
    My B6100 also drops. I have some sort of chain setup back there though that I can slip into a hook thing to keep it from dropping. Looks OEM to me. I'm pretty sure there's a post on here somewhere about someone replacing the O-ring to fix it, just gotta search for it. I'll do mine someday The 6100 is almost the exact same machine, just a smaller motor.
    You can see the chain right below my seat near the top link. It attaches to both lift arms in a V shape.
    http://www.tractorbynet.com/forums/a...s-dscf0813.jpg
    Mike
    B6100 w/ power steering - link below
    http://www.tractorbynet.com/forums/k...has-power.html
Similar Threads
  1. What is this on my BX2350 3 pt hitch?
    By MoreCowbell in forum Kubota Owning/Operating
    Last Post: 02-18-2012, 01:29 AM
  2. 3 PT Hitch Question
    By DavidNPro in forum Kioti Owning/Operating
    Last Post: 10-08-2010, 04:11 AM
  3. 3 pt. hitch scissor high lift
    By texvet45 in forum Attachments
    Last Post: 07-16-2010, 03:32 PM
  4. 3-Point Hitch Problem with JD 2520 3 pt hitch
    By GKQ in forum John Deere Owning/Operating
    Last Post: 07-09-2010, 11:50 PM
  5. 2 pt to 3 pt tiller hitch conversion
    By fjberres in forum Customization
    Last Post: 04-08-2010, 07:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
