Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2011
    Posts
    58
    Ohio
    2010 Kubota L3700su
    Default 50 hrs service: trans oil capacity L3700su
    Hi all,
    I am doing the 50 hr service on my tractor, a kubota L3700su. I'm changing all filters and oil. Engine, HST, and Hydraulic.
    I took off both the HST and Hydraulic filters, opened the two drain plugs on the bottom of trans (but forgot about the two plugs on the axle reduction housing) and drained approx 6 gallons.
    So I go to fill up, manual calls for 6.2 Gallons for the transmission oil. I put 6 gals and 1 quart of SUDT2 in and it doesn't show up on the oil level indicator (site glass on left floorboard area). I added up to 7 gals and it still does not show. Great, now what. I'm going to drain that extra 3 qts as that is what the book calls for. To be honest, I did not know about the oil level indicator until I did this service so I don't know if it showed the proper oil level before.
    Any ideas? Let me know soon, as I will be taking the tractor out of town to brush hog this weekend.
    Btw the metal shavings on the magnetic ring inside the hydraulic filter shocked me. I am glad I am changing everything.
  2. #2
    Veteran Member johnrex62's Avatar
    Join Date
    Jul 2010
    Posts
    1,013
    Bastrop County, Texas
    Kubota L3700SUHST
    Default Re: 50 hrs service: trans oil capacity L3700su
    The oil is very hard to see in that sight glass when clean.
    Kubota L3700SUHST, AG-Meier Mohawk 5' Rotary Cutter, Armstrong AG 5' Boxblade, Armstrong AG 5' Landscape Rake
    Scotts 50560x8 50" Riding Mower
  3. #3
    Join Date
    Jun 2011
    Posts
    58
    Ohio
    2010 Kubota L3700su
    Thanks, I went and drained a little over 3 qts and can just now see a little air at the top of the sight glass. The oil was so clear, it looked like I never reached it, but in reality I was already over when I added 6 gallons. I guess by forgetting the reduction housings, the little bit of oil left caused me to overfill.
  4. #4
    New Member wildcat641's Avatar
    Join Date
    Jul 2006
    Posts
    13
    Abilene, KS
    Kubota L3400 hydro
    I did the same thing when I serviced my 3400.
    Kubota L3400 HST, FEL, toothbar
  5. #5
    Join Date
    Jun 2011
    Posts
    58
    Ohio
    2010 Kubota L3700su
    Can I ask how much metal others found on the magnetic ring inside the hydraulic oil filter? I seemed to have quite a bit of shavings and a few curly strings of metal as well. It concerns me a bit. I was expecting much smaller particles and metal sludge. I did take some pictures of the metal on the filter for evidence but not sure if I should post them.
  6. #6
    New Member
    Join Date
    Apr 2013
    Posts
    8
    The Plains, VA
    Kubota L3700 SU HST
    Same tractor, 50 hours service, same problem. We drained a couple of quarts but still don't see anything in the gauge. Drained two more quarts, still don't see anything. Any ideas?
  7. #7
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,305
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by lhfry View Post
    Raise the loader, raise the 3pt, that will "use up" oil and make the level drop. if you can see the level, then, you will know you still have too much fluid in the tractor.. you should see a little air at the top of the sight glass with the loader down and level and the 3pt down. Also of course the tractor needs to be on level ground.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  8. #8
    New Member
    Join Date
    Apr 2013
    Posts
    8
    The Plains, VA
    Kubota L3700 SU HST
    This worked - actually we raised the attachments AND parked it on a hill as another user suggested. That exposed a bit of air at the top of the gauge and we see now that there is too much oil and we need to remove some. The help we got on this site was great - saved us having to re-drain the transmission oil. So thanks alot.
Similar Threads
  1. Engine Oil
    By RoyD in forum Ag Tractors & Machinery
    Last Post: 06-16-2017, 08:29 AM
  2. KIOTI'S 'Official' position on 50 hour trans service.
    By Coyote machine in forum Kioti Owning/Operating
    Last Post: 03-18-2011, 12:13 AM
  3. Changing fluids at 50 Hrs
    By JackMentink in forum Montana
    Last Post: 10-09-2008, 10:39 PM
  4. 50 hr service on 3520
    By jmt1271 in forum John Deere Owning/Operating
    Last Post: 10-15-2007, 02:10 PM
  5. 50 hour service on the L2800 HST
    By Marcussen in forum Kubota Owning/Operating
    Last Post: 09-27-2006, 12:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
