Page 10 of 12 FirstFirst ... 789101112 LastLast
Results 91 to 100 of 116
  1. #91
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,583
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Default Re: Broken Mount For LA724
    Holy crap - your tractor looks brand new! What do you move with that thing, laundry detergent? Nice looking masts, by the way. I like the full radius around the leading and trailing edges. I think I can state without reservation that kcender now has the LA724 loader least likely to fail a mast.
    -Jim
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  2. #92
    Elite Member
    Join Date
    May 2005
    Posts
    2,806
    Balls Creek, NC
    New Holland t4.75
    kubota and your dealer did you right...
    Sometimes things just happen that are really no fault of the operator or even inherent design of the machine...
    You've got a very good dealer and are very fortunate...
  3. #93
    Gold Member
    Join Date
    May 2011
    Posts
    300
    Lebanon, TN
    Kubota GL3240
    Glad everything worked out for you. Those brackets look like they came from the factory that way, you would never know they have been modified. Very nice.
    Grand L 3240. TSC 6' Rough Cutter, 66" Bradco Rock Bucket, 7' Fred Cain Rake, 6' United BB, Northern Tool 16 Gal Sprayer, 42" Pallet Forks Land Pride FDR1672 Finish Mower. Still looking for more attachments
  4. #94
    Platinum Member kcender's Avatar
    Join Date
    Mar 2010
    Posts
    870
    Nova Scotia
    GR2120 B2650 Cab
    Quote Originally Posted by Baby Grand View Post
    -Jim
    Thanks for the kind words.I only use the tractor to move laundry detergent once a week on laundry day:laughing.The other times I use it to level off my property.I am currently leveling my back yard which is where the bracket broke.I have added a few photos of it.
    Attached Thumbnails Attached Thumbnails Broken Mount For LA724-p1000089-jpg   Broken Mount For LA724-p1000107-jpg   Broken Mount For LA724-p1000115-jpg
  5. #95
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Quote Originally Posted by kcender View Post
    I have to say there looks to be enough work there for half the members on TBN.
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  6. #96
    Join Date
    Nov 2007
    Posts
    4,583
    Windsor, CT.
    I was wondering how you had accumulated all those hours on a 2010 machine - mystery solved. You are doing civil engineering on a scale that I never would have thought to try.
    - Randall Brown
  7. #97
    Join Date
    Jul 2006
    Posts
    1,918
    New York
    JD 2320
    Yeah, kcender is now my new hero.
  8. #98
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,044
    Northern Vermont
    Kubota, Case, Deere
    Level it? That's a play ground.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  9. #99
    Join Date
    Mar 2010
    Posts
    870
    Nova Scotia
    GR2120 B2650 Cab
    Quote Originally Posted by crazyal View Post
    Exactly,it's all about the journey,not the destination
  10. #100
    Elite Member RedNeckGeek's Avatar
    Join Date
    Jan 2011
    Posts
    3,206
    Butte County, California
    Kubota L3240D HST, RTV900
    Just wanted to say thanks for starting this thread. I have the exact same tractor and loader, and the exact same failure of the loader mounts. My situation may be even worse because I've added a much heavier 4-in-1 bucket to the setup. I bought the tractor from a fellow that was using it to clear land in the Santa Cruz mountains south of the San Francisco Bay Area, and from the looks of the bucket and loader arms, this thing really took a beating. Both mounts were broken and weld repaired when I bought it, and both have since cracked again. The first time this happened I ground out the cracks and welded them with MIG and E70S filler, but the cracks came back in the heat affected zone of the weld. Gouged 'em out again and this time preheated to about 400F and let them cool by themselves. That worked for another couple hundred hours until one of the mounts started to crack again. I was in the middle of a job and kept using it until it broke all the way across at exactly the same place as the OP, right through the casting and the side plates that had been added in the original repair. This time I took the mount all the way off the tractor, put a bevel joint on the broken pieces, and again used preheat while welding them back together. I also added a fair amount of filler metal to the webs on the back side of the casting to help reinforce the crack zone. So far I've seen no additional cracking on that side, but now the other side has about an inch of crack that is slowly growing.
    I'm going to make a copy of this thread and take some pictures of my mounts and go have a talk with my kubota dealer. Since the tractor is 8 years old with 1800 hours on it (only a third of them mine) I'm not expecting much. But if Kubota is aware of the problem and they've revised the mounts, it will sure save me a lot of welding and grinding if they're willing to replace them at no cost to me.
    The property here is pretty steep and I've moved a lot (if you can call 200 cu. yds. a lot) of fill dirt while running sideways to the slope. I've noticed, especially when I hit a bump with a full bucket, that the upper arms of the mounts flex at least a quarter inch sideways, and that's probably what is causing the cracks to initiate. Those same side loads keep loosening the bolts securing the inner covers on the front 4WD hubs, and what a mess that makes. First time it happened I didn't catch it until the cover broke, sending the wheel and axel out in front of the tractor! My take away from this is that these little tractors are great for landscaping on soft level ground, but here in California's Sierra foot hills where the terrain is steep and full of rocks, they just don't hold up. My neighbor likes to say that Kubotas are fine for maintaining things, but you need a real backhoe to build things.
    BTW kcender, when I saw the photos of you moving those dirt mountains, the first thing I thought of was that song about the ant and the rubber tree plant
Similar Threads
  1. Tn loader mount broken
    By mojoinco in forum New Holland Owning/Operating
    Last Post: 02-14-2009, 02:09 PM
  2. Broken Motor Mount Bolts
    By woodlandfarms in forum Power Trac
    Last Post: 06-27-2008, 12:17 PM
  3. ZTR - Front Mount or Mid Mount?
    By TheChamp in forum General Lawn & Garden
    Last Post: 05-05-2005, 08:52 AM
  4. ZTR - need help deciding
    By BrianB in forum General Lawn & Garden
    Last Post: 05-03-2005, 05:41 PM
  5. Snowblower CUT Snowblower: Front, 3pt, or FEL mount?
    By Tractorganic in forum Attachments
    Last Post: 12-11-2003, 02:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
