Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jul 2011
    Posts
    4
    kubota bx2230
    Default 60" finish mower
    hi i have a bx2230 have a rottery mower (400#) would like to get a 60" finish mower (610#) can this work ? if so will i have to get extra wieghts . i dont have far to take the finish mower to field so it wont have to be lifted much.
  2. #2
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,714
    Beaver Creek, Northern Michigan
    Kubota BX2360
    Default Re: 60" finish mower
    A 60" is toward the limits of your BX. I temporarily had a 60" that I was merely horse trading on. Unless the grass is a lawn type quality. Anyhow, I got a 48" and I believe it perfectly suited for the BX. I liked it so much, I kept it and use it with my small B2320. It is also a nice match for it, although a 60" would work on it, except for the loss of tight spot handling.
    I'm sure there are lots of guys who will tell you the 60" is just fine with their BX, but having run them both, the 48" wins hands down for many reasons, in my book.
    BP
    "Some chickens, some gardens and a Kubota."
  3. #3
    Veteran Member Will_C's Avatar
    Join Date
    May 2002
    Posts
    1,678
    Upstate N.Y.
    Kubota B 2620, Toro 52" and 60" ZTRs, Kubota RTV 900
    That's a lot of weight for a BX! I think you will definitely need weights on the front-my 60" finish mower weighs 500,bs and I can tell it is behind when I point the nose of tractor uphill (B2620). You are probably close to the limit on power with your BX as well.
    Will
  4. #4
    New Member
    Join Date
    Jul 2011
    Posts
    4
    kubota bx2230
    thanks, its good to have some one who has tried this .
  5. #5
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    I run a 60" finish mower on the back of my 16 hp B7100. I would think your BX would take a 60" with no problem. I do have a front end loader to counter balance the weight.
  6. #6
    Join Date
    Aug 2009
    Posts
    502
    Topeka, KS
    Kubota B2920
    I see Woods makes a 54" 400# mower for BX size tractors.
    Woods Equipment Company - Standard-duty RDC & RD Series 54? to 72?
    Kubota B2920, MMM, FEL, 5' Bush Hog Squeeler Rotary Mower, 5' Bush Hog Box Blade, 5' RBT1560 Land Pride Rear Blade, 55 gal. Boomless Sprayer, KK Utility carrier
  7. #7
    Join Date
    May 2002
    Posts
    1,678
    Upstate N.Y.
    I'll qualify my previous statement-my brother ran a 60" finish mower behind a 16hp Massey Ferguson. It worked fine for him, but he is the type of person that mows his lawn often. A few times when he got behind on mowing, he had to drop down a gear to mow.
    I have a Woods Heritage 54" bush hog, and am happy with it.
    Will
  8. #8
    Silver Member skspurling's Avatar
    Join Date
    Mar 2011
    Posts
    249
    Missouri
    Kubota B2620
    I have a B2620, and a 60 inch Land Pride. That is the limit for the B2#20 series, as far as I am concerned. If it is dry and conditions are nice, it will handle it nice. Any funny business, and it will let you know it is there real quick. Seeing how the BX is lighter, I would imagine you would definitely need weights. It would also stick out more. I would not use one with your FEL attached. It's bad enough having the mower or the FEL sticking out on their own. Having them both on there makes it unwieldy.
Similar Threads
  1. Delay in MMM Should I Go With A Rear Mower
    By brownsl in forum Kubota Buying/Pricing
    Last Post: 07-07-2010, 10:23 PM
  2. Mowing Trade 60" finish mower deck for a Bush Cutter
    By pequeajim in forum Power Trac
    Last Post: 04-30-2010, 08:25 AM
  3. Mid-Mount Mower Rear finish mower vs MMM?
    By T185 in forum Attachments
    Last Post: 09-06-2008, 10:30 AM
  4. Value of used Kioti 60" Finish Mower
    By kiotilee in forum Attachments
    Last Post: 03-23-2008, 09:48 PM
  5. Rough cut mower vs. finish Mower
    By Iplayfarmer in forum Attachments
    Last Post: 02-13-2006, 01:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
