Results 1 to 5 of 5
  1. #1
    Member
    Join Date
    Mar 2010
    Posts
    25
    Default ZD326 rear main oil seal leak?
    What would cause a rear main oil seal to all of a sudden start to leak on a ZD326 with 400hrs? It has been about 60hrs since the last oil change and I make frequent checks on all fluid levels. Today I noticed a wet spot on the garage floor behind the mower and found oil on the frame under the flywheel. Checked the oil level and sure enough it was down a little. It is hard to get a good look in that area, but it appears to be the rear main seal leaking. Any ideas on what could be the cause.
    JD X500
    JD Gator CX
    Kubota ZD326
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    New Member
    Join Date
    Mar 2011
    Posts
    18
    Kubota L3940
    Default Re: ZD326 rear main oil seal leak?
    I have a ZD326 with 225 hours on it and the rear main seal is leaking on mine also. I talked to a dealer this morning about it and he said it was a pretty common prbolem. Said there was a tech bulletin on that problem but was no recall. Said the seal had been redesigned. I'm going to write or call Kubato and see if I can get some help on this issue.
  4. #3
    Member
    Join Date
    Mar 2010
    Posts
    25
    My mower is 4 yrs old, so I guess Kubota won't be any help. I'll contact the dealer to see if I can get a copy of the bulletin.
    JD X500
    JD Gator CX
    Kubota ZD326
  5. #4
    Member
    Join Date
    Jun 2007
    Posts
    36
    Sealy,Tx
    Mine started leaking at 200hrs. Spoke to my dealer about the rear seal problem and he said he would contact Kubota and give me a call. This was 6 monthes ago at the end of mowing season. Was hoping I could get it in and fixed since there was a known bulletin out on this problem. Stopped by the dealer to pick a couple sets of blades last month and asked if they had heard anything from Kubota. Mang said he had not heard back yet and still had my phone number and would give them another call. I am still holding my breath. I shot an E-Mail to Kubota about the problem before talking to the dealer and have received no response.
    Mine is not leaking bad enough to have to add oil between oil changes. It is just making a mess staining my garage floor,keep a diaper under my nice mower and makes the flywheel area look nasty with oil and dust..
  6. #5
    Member
    Join Date
    Mar 2010
    Posts
    25
    I use a fuel additive every time I get fuel. I had been using Stanadyne Performance Formula and switched to another brand. It was after I switched that the seal started leaking. I switched back to Stanadyne Performance and the leak stopped. Haven't has a problem since. I have a friend with a ZD331 with 1700 hrs and noticed his is leaking. He is going to try using Stanadyne to see if it has any affect on the leak. If it does I'll post a follow up.
    JD X500
    JD Gator CX
    Kubota ZD326
Similar Threads
  1. Do it yourself, oil change!
    By bird1968 in forum Parts/Repairs
    Last Post: 07-23-2011, 08:03 PM
  2. Oil & Fuel L245DT Rear axle oil seal replacement
    By South42 in forum Kubota Owning/Operating
    Last Post: 06-02-2011, 09:23 PM
  3. GM Oil Life Monitor
    By Doc_Bob in forum Oil, Fuel & Lubricants
    Last Post: 10-10-2009, 07:15 PM
  4. Oil & Fuel Motor Oil as the Hydraulic Oil in Power Trac
    By DieselPower in forum Power Trac
    Last Post: 05-19-2007, 08:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
