Results 1 to 8 of 8
  1. #1
    Gold Member
    Join Date
    May 2011
    Posts
    296
    Default Why does the La514 loader lift more than the LA524
    I figured that bigger numbers meant more lift power but the LA514 lifts more than the LA524
    Also will the LA724 fit on the L3800 or is the LA524 with biggest that will fit
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,807
    Canada
    B3200, L5740,
    Default Re: Why does the La514 loader lift more than the LA524
    Quote Originally Posted by jokergerm View Post
    The 514 will fit the GL tractors which are heavier hence more lift. And no the 724 will only fit the GL tractors
    You of course can bump up the pressure and get the same lift as the 514 but you didn't read it here.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  4. #3
    Gold Member
    Join Date
    May 2011
    Posts
    296
    Quote Originally Posted by kuboman View Post
    I know i didnt read that hear but if i was to hear it somewhere, where would i turn up the pressure
  5. #4
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    I thought that the LA 524 is the same thing as the LA 463 but that they started to measure, and thus label the loader, based on another measurement. (not sure what that is) Bottom line is that the LA 524 = La 463. Please correct me if I'm wrong!
    Also, any larger loader and you may have problems with the front axle... I bumped up my pressure to compensate for the grapple and tooth bar but was warned about going over board...
    TractorByNet.com, WAS next best thing to seat time - not any more.
  6. #5
    Gold Member
    Join Date
    May 2011
    Posts
    296
    Quote Originally Posted by teg View Post
    where does one turn this up at? it would be nice to have a little more pressure at the backhoe also
  7. #6
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    Look at the thread in my signature... or actually here, it's the 3rd post... skip to the last line and the last photo...
    http://www.tractorbynet.com/forums/k...ols-l2800.html
    DO NOT just turn it up... get the gauge and know what the pressure is. Blowing a hose is not fun and dangerous... Also, I didn't have to mess with mine too much, I just tighten it down a 1/2 turn (if I remember correctly).
  8. #7
    Join Date
    Dec 2009
    Posts
    1,807
    Canada
    B3200, L5740,
    Your power beyond port is below your right foot under the floor panel. The relief is on the bottom of that. Like has been said get a gauge and check first and then don't go over the rated for the loader you want to match. Be warned that if this is a new tractor that anything related to hydraulics your warranty will be worthless. Personally I would not be afraid by going up 2-300lbs in pressure but I am a gambler.
    L5740 LA854 loader
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  9. #8
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    4,636
    Lancaster County, PA
    thats correct, the measurement was always at bucket center.. they are moving back to pivot pin as new models are released. The 514 is a much larger loader than the 524 even though the number is bigger.
Similar Threads
  1. loader won't lift with different cylinders
    By vermonter85 in forum Hydraulics
    Last Post: 08-04-2011, 10:33 PM
  2. Replies: 13
    Last Post: 07-08-2011, 02:44 PM
  3. Loader won't lift
    By DIXIEDOG in forum Hydraulics
    Last Post: 05-10-2009, 07:10 PM
  4. Increasing loader lift
    By arrow in forum John Deere Owning/Operating
    Last Post: 03-11-2008, 11:00 PM
  5. Front loader won't lift tractor
    By B_D in forum Kubota Owning/Operating
    Last Post: 03-30-2005, 12:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
