Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jan 2007
    Posts
    12
    Default B7100 Front Differential
    Hi
    I have an older B7100HST. I was wondering what each bolt was for on the attached pictures. Is bolt #1 on the axle used for checking the level and filling? What are #2 and #3 used for. Does bolt #1 fill the entire case? Should I be able to see the oil level inside. How much fluid does entire axle take? Thanks!!!
    Attached Thumbnails Attached Thumbnails B7100 Front Differential-diff-001-jpg   B7100 Front Differential-diff-002-jpg
  2. #2
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Default Re: B7100 Front Differential
    #1 is an oil fill port, #2 and #3 are bump stops for the front axle. They keep the axle from moving to far up or down as the axle articulates.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  3. #3
    New Member
    Join Date
    Jan 2007
    Posts
    12
    How much oil should be in there? Would you be able to see the oil in the fill port? Does that oil fill the entire differential and axle?
    Thanks
  4. #4
    Elite Member
    Join Date
    Sep 2004
    Posts
    2,565
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    You should have a fill to plug on the front or back of the housing....
    You should not fill so full that the oil level covers the driven shaft, it will be partly up on that shaft, about a third up... KennyV
Similar Threads
  1. Front differential problem on b21 - any one want to help an idoit out!?!
    By Dawgbrain in forum Kubota Owning/Operating
    Last Post: 07-12-2011, 02:52 PM
  2. Dual Brakes on an HST tractor
    By Lockport in forum Owning/Operating
    Last Post: 07-06-2011, 10:58 AM
  3. 3316 Front Differential; any yellow metal
    By bnmccoy in forum Mahindra Owning/Operating
    Last Post: 06-26-2011, 02:14 PM
  4. Tires Tires sizes
    By Conservation in forum Owning/Operating
    Last Post: 12-26-2008, 08:26 AM
  5. B7100 Rear Differential Oil Change
    By Shootingstar in forum Kubota Owning/Operating
    Last Post: 01-19-2006, 05:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
