HST Problem Solved?
   / HST Problem Solved? #1
jerkyboy
Upstate NY
So I took my HST apart and found that the bottom of the cylinder block on the pump side scored the port block (not sure if that's what its called) pretty heavily and the cylinder block on the motor side scored it, but not nearly as bad. Otherwise, the inside of the HST looked fine. I've attached some photos but would love to know the cause.
   / HST Problem Solved? #2
How many hours are on your BX? Did it have the filter and fluid changed when recommended by Kubota? I had a service man tell me that the HST is much more sensitive to anything in the fluid than the hydraulic pump.
It has 480 hours and the fluid was changed at 3xx with a Kubota filter and their SUDT2. All fluid changes have been done per factory recommendations.
   / HST Problem Solved? #4
Wow, that doesn't look like 480 hours...very interesting. Did you cut open your filter and see if anything is abnormal?
Deano
   / HST Problem Solved? #5
I had my hst backing plate resurfaced and I replaced both pumps.
Deano
Not yet, but I will and post the results. When I took out the tranny screen and saw metal filings I figured something was up.
Just like having a flywheel resurfaced.:thumbsup::thumbsup: Great idea, I didn't think of that but I've already got a new HST on the way. I just need to figure out what caused it so it doesn't happen again. I'm thinking of replacing the priority flow valve per mattj's suggestion from another post.
   / HST Problem Solved? #8
Do the surfaces look pitted at all or just scored?
What did the slippers on the pistons look like?
Was there any scoring or marks on the swash plates? I.e. Slipper wear plates
Since these are "closed loop" usually when one component (pump) starts to wear it puts the trash into the rest of the components (motor).
Do you use this for plowing snow in the winter? FEL, blade, or blower? Does it sit in a cold building or heated building?
Do you use it mostly for mowing lawns or lots of FEL work.
Just trying to get a feel for use which may help narrow down some possible causes.
Roy
   / HST Problem Solved? #9
You should not have the port block (yes, that is the correct term) "resurfaced", just not a good idea. Just looking at the pictures, it looks as if the charge pressure for the system was low. But I admit that it is strange to see that type of damage on 1 side only. On the BX, the charge pressure is created by the main hydro pump (if I remember correctly) and a regulator valve the splits oil off to steering, pto, and hst. I would check the charge pressure after reassembling.
Roy
Not sure what the slippers on the pistons are. I did a pretty thorough look over of the internals and that is all that I noticed but I'll check again later this week.
The prior (original) owner did use it every winter for snow blowing. He also had it dealer serviced (I have all the receipts) during his ownership. The tractor does sit in an unheated garage, but mine is very well insulated and does not typically go below 30 degrees.
I use it mostly for mowing and I have the Kubota leaf system, which I use extensively in the fall. The problem started happening when I was moving crushed stone (6 ton) and leveling out a small area with the FEL.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2017 Caterpillar 259D (A53317)
2017 Caterpillar...
Black Tip Steer Horn (A55853)
Black Tip Steer...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
