Bring It On In
Of course, you'll want to be sure to do a small job with the tractor before bringing on into the shop. It's best if the fluid have been warmed and circulated a bit before draining. This doesn't mean you have to risk First degree burns. Let it cool down a bit, if you got it really hot.
Assemble your tools.
The first thing to do is check the lug nuts. It may be that you've checked them monthly or never have before. This would be an ideal time to check them. If you have an airgun and compressor, use it. Whatever tool you have, tighten those lug nuts!!!
Have some sand or sawdust spread under the front end of the tractor, or have some ready, because it seems no matter what you do, you'll drip, splotch or spill some fluids on the shop floor. That's what oil dry, sawdust or sand is for. Don't sweat it.
Have a couple of oil catch pans. I used a very deep one and a shallow version with a pouring spout. Let's start with the engine. Pop the hood, and loosen the two thumb screws. This enables you to tilt the grill forward. No need to actually remove it. The side curtain panel has a "keeper", as shown. Simply life. The entire curtain is now free to remove out of the way. Easy and no tools required.
Start by removing the old oil filter. You'll need an oil filter wrench of some kind and there are a number of choices. Cups, band wrenches, giant "claw" type filter wrenches, etc. Use what you have or can buy/borrow. I happen to have a #3 cup. In fact, I have all the sizes, collected over the years. The oil filter for the Kubota is the same filter used by Honda cars and many, many others.
On the my particular engine the radiator hose rubs on the oil filter. Just is what it is. Also, there are some wires there. Just make note of obstacles such as these and gently work around them.
Have a catch pan down below and remove old filter. Lighten oil the rubber gasket of the new filter and spin it on. I like to use the cup wrench to make a snug fit, but there's no need to King Kong it on.
Under the tractor, find your oil pan drain plug. Mine was the only plug in the oil pan. 14 mm. Very common Japanese size. Easy right? Well, not so fast. Turns out the bottom brace of the FEL is smack dab under the oil drain plug. Nice!
Ok, there will be a bit of shower of oil, going a few directions when loosening the plug. Have an over sized pan ready. This isn't going to be a nice single stream. Seen this many times before on cars and trucks too. Nothing new.
Once the oil stops dripping, usually within 10 minutes, re-install the plug. Take your time, don't cross thread it. Fingers only, snug it up. Snug the plug tight, but again, there is absolutely no need for King Kong. If you use 3/8 drive socket wrench or an open end wrench of 8" length, there will less tendency to over tighten. Put that 2 foot cheater bar back!! No oil plug needs to be THAT tight.
Head up to the top of the engine. Remove the oil cap and ready an oversized funnel. "Easy Pour" sounds good on the jug label, but in the real world, an oversized funnel is your friend.
Put in 3 quarts. Again, different engines will vary slightly, but only put in 3 quarts for now. If you need 1/3 quart more, there'll be time to add that later. Over filling is not a good thing. Under fill until you run the tractor, let the oil settle down, and re-check. Mine took 3 and 1/3 quarts. YMMV.
