Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2009
    Posts
    78
    Southeastern MA
    BX2660 with FEL
    Default BX2660 3ph question / control knob
    I'm trying to lock out my 3ph moving up and down following my manual which states to turn the 3 point knob clockwise to lock it. When I do this my 3ph still moves up and down but my mower deck, which I want to be able to raise and lower, doesn't move.
    If this knob is working as it's supposed to and there's no issue with my tractor shouldn't I be able to raise/lower my mower deck without the 3ph moving at all? I'm using my cyclone rake to clean up my yard and I'm lifting this up and down which I don't want to do.
    What am I doing wrong?
    BX2660 with FEL
    54" Fine Cut Deck
    Timberwolf TW-P1
    OMNI-MFG 3pt hitch
    OMNI-MFG Boom Pole
    TSC Carry-All
    Husky 576XP
    Husky 55
    Cyclone Rake XL
  2. #2
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,948
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: BX2660 3ph question / control knob
    Your 3PH actually raises your MMM, so you really can't operate the MMM without the 3PH moving, the lockout just holds the MMM in position.
    We had our JD 2305 fixed so they would operate independently by using a hydraulic ram to lift the deck, but kubota doesn't offer this as an option.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  3. #3
    Join Date
    May 2009
    Posts
    80
    Illinois
    Kubota BX2660
    Default
    If you look at the linkages for the three point hitch you can unhook them from the lift arms and pin them solid to the frame. This will allow the three point hitch to stay up and still raise and lower the mower deck. There is another knob that adjusts the speed of drop of the deck and three point arms. If tightened this will hold the deck and three point up.
    BX2660 3ph question / control knob-image-2797657935-png
  4. #4
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    2,457
    Conn. & Florida
    Kubota BX25
    Here's a few pic's of a hitch one member made to attach his Cyclone Rake to the tractor frame (vs 3PH). This moves the CR closer to the tractor making the overall length less (good for tighter areas) and solves the issue of the CR going up and down with the MMM. Now I just need to make one for my BX/CR.
    Attached Thumbnails Attached Thumbnails BX2660 3ph question / control knob-cyclone-rake-hitch-1-jpg   BX2660 3ph question / control knob-cyclone-rake-hitch-2-jpg
    Chris
  5. #5
    Join Date
    Aug 2009
    Posts
    78
    Southeastern MA
    BX2660 with FEL
    Thanks for the help guys.
    Chris, make 2 and I'll buy one from you!
    BX2660 with FEL
    54" Fine Cut Deck
    Timberwolf TW-P1
    OMNI-MFG 3pt hitch
    OMNI-MFG Boom Pole
    TSC Carry-All
    Husky 576XP
    Husky 55
    Cyclone Rake XL
Similar Threads
  1. Buying Advice Position control hitch question?
    By smalltown in forum John Deere Buying/Pricing
    Last Post: 06-14-2011, 12:06 PM
  2. L2800 L3400 3ph question...
    By teg in forum Kubota Owning/Operating
    Last Post: 03-24-2010, 08:41 PM
  3. Removing 3ph on BX2660
    By dvmccll in forum Kubota Owning/Operating
    Last Post: 01-20-2010, 06:21 PM
  4. Valve Spool, Control Valve questions
    By woodlandfarms in forum Hydraulics
    Last Post: 01-18-2010, 04:34 PM
  5. BX Control Valve Question
    By ewoz in forum Kubota Owning/Operating
    Last Post: 11-18-2008, 08:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
