Thanks for the suggestions so far.
To try and help come up with an answer, i ran out and put a piece of plywood under the deck and took some measurements. The deck was in the upper position for most of them as i couldnt get my tape underneath to measure otherwise.
left front
Left rear
Left profile
looking under deck from left
right front
right rear
Deck at cut height , 3 on the dial
As you can see there isnt a huge differance from left to right, hardly any actually.
I coud perhaps stand to lower the leading edge a bit as the blades appear to be flat.
I know that having the deck raised all the way could interfere with the measurements, but until i come up with a way to measure at cut height im stumped
Mozark: the blades are for a 54. Threre was next to no clearance to the mulch baffels when i installed them
Radioman:
The pictures are hard to see, but their are 2 distinct paths where the grass is uncut. Both those paths are directly inline with the fromt wheels. If a blade wasnt cutting i think the uncut path would be easy to see.
I cant really remove the baffles to see if that changes anything, as its all one piece and id have to completely remove the kit and blades.
The type of grass is some pasture with some bluegrass. there arent that many weeds surprisingly.
