My G1900 won't even turn over. I pulled the starter and applied external power and the solenoid and starter do what they are supposed to. Gear spins and is thrown forward to engage the flywheel. But when it is on the tractor it will only turn a bit and then stop...... I turned the crank several rotations by hand from the front of the motor and it does not bind up as if something is internally wrong. I checked the oil and it is dark with no water in it so I don't think overheated and locked up......When the starter is out of the tractor it operates freely when it is on the tractor it is as if the battery is dead and can't turn the engine over. I have tried a new battery with the same result. Do I have a bad starter when under load of the flywheel can't do its job or did I bind up the motor somehow......any help would be appreciated.
