Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default L48 rear aux hydraulics
    [image]c:/Pictures/Dsc00033[/image]
    Attached Images Attached Images
  2. #2
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Re: L48 rear aux hydraulics
    more photos of L48 rear
  3. #3
    New Member
    Join Date
    Sep 2005
    Posts
    0
    More pictures of L48 rear hyd.
  4. #4
    New Member
    Join Date
    Sep 2005
    Posts
    0
    More pictures of L48 HYd.
  5. #5
    Join Date
    Sep 2000
    Posts
    1,862
    The Fabulous Foothills of Northern California
    MikeA, your handy work with the hydraulics on the L48 is slick. Your pictures are probably lost on most folks as I'm pretty sure they haven't a clue why your posting them. Finding a good place to mount your remotes can be tough since it requires you to keep the hoe area available and free while still allowing for TnT hose movement. I mounted 3 pairs of remotes on my L48. I use all three constantly. I do not have a hoe, but if I did, they are out of the way and very easy to get to. I have the factory setup and really like the controls for it. No play and very responsive and accurate. You did a nice job, Rat....
  6. #6
    Gold Member uhmgawa's Avatar
    Join Date
    May 2003
    Posts
    282
    New Hampshire
    Kubota L48TLB
    </font><font color="blue" class="small">( MikeA, your handy work with the hydraulics on the L48 is slick. Your pictures are probably lost on most folks as I'm pretty sure they haven't a clue why your posting them. Finding a good place to mount your remotes can be tough since it requires you to keep the hoe area available and free while still allowing for TnT hose movement. I mounted 3 pairs of remotes on my L48. I use all three constantly. I do not have a hoe, but if I did, they are out of the way and very easy to get to. I have the factory setup and really like the controls for it. No play and very responsive and accurate. You did a nice job, Rat.... )</font>
    That is a nice job. And one which I need to do as well.
    I'm curious where either of you chose to break the circuit
    for your work. I've looked at this and the hard line
    between the front hydraulic block and the accessory
    directional valve looks like an opportune location.
    (I'm assuming the main pump rather than the swing pump
    was used.)
    My local Kubota dealer doesn't seem able to do much
    for me other than telling me the hard line is a JIC37
    flare. However it looks like I can separate the line
    at the rear valve and jog it by an inch or so. That
    would leave me with a JIC connection on the line and
    an SAE into the directional valve. For the tank return
    it looks like replacing the 90 elbow going to the
    backhoe quick connect with a tee will be an easy
    solution.
    Comments/advice/war stories welcome.
  7. #7
    Join Date
    Sep 2000
    Posts
    1,862
    I just plugged right into the backhoe quick couplers. It's how its done by the factory TnT. The two quickcouplers on the right hand side. The one on the left remains unused. The valve on the right is put in the backhoe position, the left one remains in the non backhoe position. It's really simple. Fluid return goes into the filler cap. The cap is replaced with a aluminum one that allows the return hose to be attached. There are other ways to get the fluid back as well. I welded up my own bracket for all six quick couplers and attached them just above the fender. Rat...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
