riprap
Member
I have a BH75 that I have not used much (say less than 10 hrs) that is about 6 years old - it has been stored indoors, and is in like-new condition. I use it on my B2630, which is used all the time and has given me no trouble at all - the loader has about 300hrs on it.
The problem is that I have had several strange hydraulic hose failures (1/8 inch or so blowouts).
The first failure was in the line from the swing valve to the distribution block - this is a stationary hose, is totally protected under the deck, doesn't move at all. I chalked it up to a manufacturing defect and replaced it. The line failed after 10-20 minutes of use.
The second failure happened in another hose for the swing circuit, this time one of the hoses that goes from the distribution block to one of the swing cylinders. The blowout occurred after only 15 minutes of mild use, the hydraulic fluid and lines were still at ambient temperature (70 deg ). Again a well protected, new looking, basically stationary and non-chafed line. Both blow-outs were 1-2 inches from the crimp.
Anyone have any ideas what could be going on ?
So far I have been lucky that these are easy access lines. Am I correct that this can't be a pressure relief problem - the loader has never had a problem - and these are 3000psi rated hoses - with the relief supposed to be set around 420psi ? (haven't measured it yet) - it would be a serious and obvious problem to get anywhere near that hose failure limit?
Anything special about the swing circuit ? Bad batch of hoses years ago ?
Any ideas but keep replacing them ?
Thanks all.
Thanks all.
