Rough Running BX
   / Rough Running BX #1
jcgaylord
Rough Running BX *SOLVED*
I finally solved a problem with my BX running rough and wanted to share solution.
I trolled this forum and others the past few months to try and troubleshoot the problem. Tractor would run fine for a while (15 minutes, an hour?, 2 hours?) and then start bogging down and have no power. RPM's all over the place and almost stalling out. Sometimes sitting would help but it always returned. First time I changed both fuel filters and thought it was solved but a month later the problem returned. I read and tried everything from new diesel source, more filters, purging air, etc. but it kept returning. I noticed when it happened if I disconnected fuel line before first filter from tank it would dribble out. I tried blowing air back through line and immediately flow was like it should be (pouring out). I surmised that something was stuck in the tank outlet. So I finally got around to removing the tank today which is no fun. I did ball joints on Dodge last week and that was almost easier. Anyway after a couple hours of disassembly and taking time to thoroughly remove leaves, grass, twigs from every nook and cranny and degreasing everything I had tank off. With it empty I shook it into a white pail to see what I had in there and a lot of rust flakes came out. By a lot I would say half a teaspoon. Being a plastic tank I was curious how this could be? So I removed the fuel sender float and sure enough it was rusted and crumbling. I was shocked how bad a shape it was for a 3 year old tractor. I am glad I found the problem but am worried this could be a regular occurrence. I should also mention that before I did all this I did try and blow air out of tank. I made a tight seal with rubber glove ducktape around an air gun. I blew air and got some mist coming out of fuel line but problem still came back. After taking it apart and seeing the size of the outlet at bottom of tank, and the odd tank shape. I think it would be unlikely I would ever get all the rust flakes out. Not to mention it would keep occurring as more rust flaked off sender unit.
The picture I took is of sender and I scraped the side lightly just a couple times to show how easily it was flaking.
The disassembly is fairly straightforward. You need to take off seat, rear fender and loosen floorboard. I took floorboard off to easily clean things and do new filter. A lot of knobs and some electrical connections too. I did not do a write-up but found it pretty intuitive once I started. The only thing I will point out is the knob below seat (which controls how quickly rear three point raises/lowers) takes a lot of prying force to come off. The knob for the cutting height takes even more. I used long screwdriver as a fulcrum and pried each side slowly for a few minutes and they finally popped off.
If you have any specific questions I can try and answer them but hopefully this might save some guesswork if you are running into same problem.
some follow-up stuff:
- Forgot to mention this is for BX1850 but I think all BX's used same fuel sender.
- I have always used a diesel fuel additive to prevent gelling and algae
- The part (K2581-61370) is ~ $50 but since it was special order I decided to try and see if I could clean mine up and maybe coat with POR or something. Not that I am cheap I just am impatient. I started wire brushing lightly and once surface rust was off I found a lot of holes in outer case where rust had eaten through. Upon opening outer case I found inside was worse than outside (see pic). So no saving this part and I will wait (impatiently) for a few days.
   / Rough Running BX #2
Yuck ......... I think I'd invest in a new fuel sending unit. They are about $50. How could it get that rusty?
   / Rough Running BX #3
Geez.....what could do that? If the tractor was 10-20 years old, one might expect something like that. Thanks for your investigative and knuckle knocking effort. .. ...I'll be following this thread.
   / Rough Running BX #4
Great tip... thanks for posting!
   / Rough Running BX #5
Intersting. Wonder if you had a few bad tanks of diesel with lots of water in it??
   / Rough Running BX #6
That is interesting. I wonder if its corroded, and not really rusted. I can't imagine it would rust, unless it had a lot of water in the tank and it sat that way for a long time. I'm guessing that might be a part that should be made out of something different, like stainless. Good write up and it might save people a lot of time in the future.
   / Rough Running BX #7
Thank you for the heads up. You may be saving us a lot of trouble.
One question I would like to ask is, did you keep the tank filled through the winter? If not full, that would leave the sending unit in the air so it could rust.
I ran onto something like this with a gas powered woodchipper. I left the tank low over winter and got rust in it.
   / Rough Running BX #8
thanks man hi will check my tractor if its like that too he run good but that fuel gauge they all the same thank you mario
   / Rough Running BX #9
Are you using biodiesel and do you keep your tank full.
Where do you live?
Is it a warm humid climate?
   / Rough Running BX #10
Wow...that had to have sucked to have todeal with that mystery/intermittent problem for months.
My next question is not meant to add to your troubles, but are the pumps on these tractors lubricated AT ALL by the diesel fuel itself? The reason I ask is, on older Mercedes-Benz cars, if an owner put gas in the tank by accident, it did not damage the fuel pump, because the diesel was NOT part of the pump's lubrication system. However, do the same thing on one of the '80's GM 350 diesels, and it would require a new pump, as the diesel FUEL itself was the pump's lubricant. I'm just concerned that your periodic fuel starvation hopefully did no damage to your pump. I'm sure actual techs could chime in here on that point?
Re: the degree of corrosion itself, I'm just shocked--I mean, on for a three year old machine. I too would like to know if if was your practice to leave the tank less than full often (no offense), and if you life in a damp/salty climate?
Thanks for the excellent diagnostic work, great pics and solid efforts!
To All: is it just me, or does it seem like there are more problems, lately, with (what I consider to be) rather expensive, LATE MODEL, allegedly high quality machines like these Kubotas? I'm thinking of the backhoe with the snapped off dipper stick, the brand new tractor with the "runaway" (over speeding) engine, etc.... (Don't flame me--this is something that's actually been bothering me lately--and I'm obviously an Orange fan...).
Oh! And WELCOME and GREAT FIRST POST!
Thanks again.
My Hoe
Ford 8510 (A53317)
Ford 8510 (A53317)
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
Kubota KX057-4 (A55272)
Kubota KX057-4...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
403 (A52706)
403 (A52706)
UNUSED BULL AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED BULL AR500...
