Results 1 to 10 of 19
11-21-2011, 12:14 PM #1Bronze Member
- Join Date
- Apr 2009
- Posts
- 69
- Location
- Virginia Beach and Lexington Virginia
- Tractor
- Kubota L3400 HST 4WD
Backhoe working like a charm
I've have had my BH 76 now for several years and combined with my L3400 HST, it gets the job done and then some. I've moved larger rocks when I was digging out the slope and preparing the pad for my wood shop, but my wife had a camera in her hands when I was digging out this monster. Once I stood it up, I had to drill it and use Dexpan to break it up into moveable chunks.
11-21-2011 12:14 PM # ADS
11-21-2011, 12:32 PM #2Elite Member
- Join Date
- Aug 2011
- Posts
- 3,185
- Location
- Schuylkill County Pennsylvania
- Tractor
- Massey 1423 Hydrostat
Re: Backhoe working like a charm
There's alot of power when you curl the bucket.
Massey 1423, 1462 loader, wallenstein Ranch ho gx620, with subframe mount.
11-21-2011, 12:49 PM #3Platinum Member
- Join Date
- Dec 2007
- Posts
- 556
- Location
- Southern Rhode Island
- Tractor
- Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
Nice job! At the risk of being a busybody, I've got to tell you - you really shouldn't have that tractor so high off the ground when you're digging. The stabilizers are just that - meant to stabilize. They work best when the load is just taken off the wheels but the wheels are still making a little contact with the ground. Same with the front end. I know all the Kubota pics show the bucket dumped full as you have it - and it works great like that - but it puts a tremendous amount of stress on those fully exposed curl cylinders.
I've got the BH-75 and I know how strong the hoes are for our light tractors. They will drag the machine all over the place. Four wheels on the ground will help stop the tractor from dragging much better. There really is no benefit to lifting the tractor up as high as it will go with the stabilizers.
Another thing I've done is bolted 'cleats' onto my stabilizer pads so they grip better in soft ground, rather than sliding around. Can be done very easily with a couple pieces of heavy angle bolted into the holes that the street pads bolt onto.
11-21-2011, 01:11 PM #4Elite Member
- Join Date
- Aug 2011
- Posts
- 3,185
- Location
- Tractor
Nspec your wright about the stabs being too high, yet at the same time you see alot of construction workers doing the same thing.
11-21-2011, 01:16 PM #5Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,953
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
It appears that your backhoe is surely capable of doing the job. Enjoy your seat time and good luck with your project. Please stay safe.
The PUPIL who does not surpass his Master, fails his Master.
11-21-2011, 01:46 PM #6Platinum Member
- Join Date
- Sep 2010
- Posts
- 643
- Location
- Eastern Ontario
- Tractor
- Kubota MX5100
2011 Kubota MX5100, BH92, BH BB72, Walco Bush Hog and Snowblower, Wallenstein 310 Splitter & Forks
11-21-2011, 03:01 PM #7Veteran Member
- Join Date
- Jul 2009
- Posts
- 1,303
- Location
- IL
- Tractor
- B2710
My experience is that construction workers are the poster child for what not to do when it comes to machine damage or safety.
Is this the 3pt backhoe, or is it on a subframe? Everytime I go on a backhoe purchasing fantasy I get derailed trying to figure out which kind to get.B2710, LA402, PHD, 5' Ford 908 bush hog, New Idea manure spreader, dump trailer, 3PT generator, Swisher trail mower, Toro Zmaster ZTR mower
11-21-2011, 06:28 PM #8Silver Member
- Join Date
- Sep 2011
- Posts
- 121
- Location
- South eastern Pa.
- Tractor
- kubota B26
I have read several times on this site about the stabilizers being to high. I am not sure I agree. I for one like to get the wheels up off the ground and have no problem with the tractor moving around when they are. What I don't like is to be digging and discover my wheels are on the ground. If the wheels are on the ground while digging it is my humble opinion there is load being applied to the axles. I don't see how that can be good. Even with my B26 and only 150 hours the stabilizers drift down while digging. There is a lot of load on those cylinders. I check frequently to be sure my wheels are off the ground. I also generally keep the tractor out of gear while digging.
I am very interest to hear other opinions and input on this question. I guess the issue is are the axles and transmission meant to receive load while digging.
I do walk my machine while digging to re-position. When I am doing it I have the stabilizers close to the ground and the bucked in scoop position and lightly on the ground. The machine is very stable this way and walks easily. The tractor is in neutral for this operation also.
11-21-2011, 06:48 PM #9Bronze Member
- Join Date
- Jan 2010
- Posts
- 99
I happen to have the Ober book from a local library right now.
He suggests 2 points.
Tires, front or rear, on the ground will 'give' as the hoe moves and the give will 'echo' throughout the whole motion and operators body parts! I can vouch for that - less over shoot and shake when all the wheels are up and FEL bucket and stabilizers down.
Once the tires are up, you next want the widest stance you can set - typically setting the wheels at the lowest stance where they are still barely up - should leave the 2 stabilizer pads at the largest distance between. They would then resist the greatest torque / angle 'lever' force trying to move the machine. A higher cab is 'tippier' and the 'lever' to resist force is shorter also.
11-21-2011, 06:48 PM #10Silver Member
- Join Date
- Mar 2011
- Posts
- 124
- Location
- Summit, MS
- Tractor
- Mahindra 5035, MF250, New Holland LS190, JD Gator 6x4
.load being applied to the axles
Hello.....It's a tractor!Mahindra 5035 PST, MF 250, Jinma LW-8 BH, Kubota 72" ZD331, NH LS190 SS, JD 6x4 Diesel Gator, SS backhoe attachment, Markham grapple, Markham stump bucket, Markham tooth bucket (awesome), 6" Jinma chipper, 72" King Kutter tiller, 72" box blade, 72" rotary cutter, 72" landscape rake, homemade hydraulic post hole digger, homemade 16' boom, homemade pallet forks
Similar Threads
Ford New Holland 345C with 764 backhoe needs hydraulic installation kit
By specter in forum HydraulicsReplies: 21Last Post: 12-17-2011, 02:39 PM -
Backhoe 12" versus 16" Backhoe Bucket Size
By Don_Curley in forum Kubota Owning/OperatingReplies: 18Last Post: 07-27-2009, 04:12 PM -
Help - Backhoe Hydraulics !!!
By bbarnes871 in forum HydraulicsReplies: 5Last Post: 10-24-2008, 03:27 AM -
Backhoe & Power Beyond Question
By R_squared in forum HydraulicsReplies: 20Last Post: 09-28-2008, 01:44 PM -
Backhoe Backhoe working properly?
By B7500 in forum Owning/OperatingReplies: 6Last Post: 09-24-2002, 09:22 PM
