Results 11 to 14 of 14
11-22-2011, 08:19 PM #11Silver Member
- Join Date
- Apr 2010
- Posts
- 110
- Location
- U P of Michigan
- Tractor
- BX2660
Re: Buying loader - Ballast box or Carryall with box
I have a BX2660 w/ LA243 and went with the box blade @ 382 pounds, filled rears and wheel weights. Have had no problems.
11-22-2011, 08:30 PM #12
The nice thing about a ballast box filled with concrete is, it's close to the tractor and don't hang way out to the side. You door on your garage or your trees will thank you. You will bang into them sooner or later. If you just need weight and aren't around any trees or building and are real careful when you turn, maybe an implement of some sort will work.
I was using a box blade for weight and was working around trees and backed into a tree and the lift arm just curled up on me. I like compact.
I have a ballast box and a heavy box blade. Give me a ballast box anytime for just digging and rutting around. If you have to dig and scrape and move dirt from here to there, maybe a box blade would work.
Many owners manuals advise to load the tires with Calcium Chloride or Rim-Guard or whatever works in your area and to put something on the rear 3pt. You have to figure out how much weight exactly.. I wouldn't worry about punctures unless from past practice you get a lot of them.
Filled tires and a ballast box or equivalent sure helps with FEL work and your front driving wheels won't take as much of a pounding because the rear weight will put more work on the beefier rear wheels.3720, Frontier 6' BB; 6' Rear Blade.; Loaded tires and Ballast Box; Dirt Scoop.
X740; 62" Deck; w/47" Snoblower; 42" Hydraulic Tiller.
54" Front blade; 48" Belly Blade
11-22-2011, 08:40 PM #13
I use a box blade as ballast for medium/heavy loader work. It turns the BX2360 into a different animal in terms of traction.
2010 BX2360, 54" MMM, 5' TW rear blade, 5' TW rake, 4' Frontier Box Blade, Male Red Fox Labrador Retriever
11-22-2011, 08:57 PM #14Bronze Member
- Join Date
- Oct 2011
- Posts
- 83
- Location
- Tennessee
- Tractor
- Kubota bx 2360
I have a rototiller, it's probably heavy enough but I'm concerned about ground clearance. (for the tiller)
Originally Posted by Mac25
Similar Threads
John Deere Ballast Box
By NYBOB in forum AttachmentsReplies: 3Last Post: 04-23-2008, 04:21 PM -
Box Scraper box scraper as ballast
By bgWI in forum AttachmentsReplies: 18Last Post: 02-22-2007, 06:52 PM -
Loader Ballast
By DFB in forum SafetyReplies: 14Last Post: 01-20-2001, 07:17 PM -
Ballast Loader ballast
By huckflynn in forum Kubota Owning/OperatingReplies: 33Last Post: 10-16-2000, 10:26 AM -
Ballast B2710 - Rear Ballast for Loader Work
By DRFoster in forum Kubota Owning/OperatingReplies: 16Last Post: 08-13-2000, 09:23 PM
