Page 1 of 13 123411 ... LastLast
Results 1 to 10 of 130
  1. #1
    Bronze Member j t huskins's Avatar
    Join Date
    Sep 2011
    Posts
    95
    Boone N.C.
    Ford 1210 4x4 With Ford Front 3 Way Snow Blade ,Newholland TC40A 4x4 With NH 16LA FEL,Kubota B7100 4x4 With Kubota FEL Project Tractor, Ford 1210 4x4 Parts Tractor.
    Default B7100 Restore Project Has Begun
    Began working on the B7100 that I brought home in August. The tractor had set for three+ years with the upward exhaust uncovered. I resisted the urge to just try and crank the engine before doing some investigation into possible water damage to it. Good thing I did. Even though the engine was not stuck it did have rust in no. 2&3 cylinders along with stuck rings. Some water found its way to the crank no. 3 rod and main journals which made a small rough spot on both. No. 1&3 cylinder walls have a ring groove worn at the top. I began the task of finding and pricing parts and was shocked to discover the high price of each component.Before I waste any time or money purchasing parts I will wait for the verdict from my machine shop as to whether the cylinders can be cleaned up with a .5mm bore and the crank can be turned within the under size bearing specs offered by kubota. I have pictures but haven't figured out how to ad them to my post yet.
    Attached Thumbnails Attached Thumbnails B7100 Restore Project Has Begun-imag0169-jpg   B7100 Restore Project Has Begun-img_2091-jpg   B7100 Restore Project Has Begun-imag0168-jpg   B7100 Restore Project Has Begun-img_2069-jpg
    NHTC40A 16LA FEL
    Ford 1210 4x4 Front Blade
    Kubota B7100 Kubota FEL
    CubCadet 1554
  2. #2
    Super Member timswi's Avatar
    Join Date
    Nov 2008
    Posts
    5,646
    Beaver County Pa
    Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris Sportsman 570 Touring
    Default Re: B7100 Restore Project Has Begun
    Keep us posted, sounds like an interesting project.
    To post pictures, just hit the paper clip on the TBN post menu and find your picture folder, then upload
    BX23TLB with 54" MMM
    RTV1100 with 72" Power Angle Plow
    Z724 ZTR
  3. #3
    Elite Member WayneB's Avatar
    Join Date
    Oct 2006
    Posts
    2,829
    New Hampshire
    Kubota B-7500
    Default
    Good luck with the refurbish! Sounds like a major undertaking.
  4. #4
    Join Date
    Sep 2011
    Posts
    95
    Boone N.C.
    Yea, i'm afraid that an undertaking might become an under statement before this is over. I can carry on with the news that the block wiil need to be re sleeved but if the crank can't be turned then the project will have to be scraped and the tractor parted out unless I can locate a good used crank that is reasonably priced.
    Attached Thumbnails Attached Thumbnails B7100 Restore Project Has Begun-img_2066-jpg   B7100 Restore Project Has Begun-img_2074-jpg   B7100 Restore Project Has Begun-img_2081-jpg   B7100 Restore Project Has Begun-img_2067-jpg
    NHTC40A 16LA FEL
    CubCadet 1554
  5. #5
    Gold Member Mudfarmer's Avatar
    Join Date
    Dec 2009
    Posts
    250
    Western Washington
    John Deere 3005, Kubota B7100, Kubota B2710 (Traded in the Ford 1700)
    Quote Originally Posted by j t huskins View Post
    Be careful. I have a B7100 and love it, just bought new tires for the front - $300 plus. Looks like your tires are worn in the back, pretty expensive to replace. I see B7100s offered for abouyt $5000 on Craigs list in our area. Doubt they are going for that much, especially if you don't have a loader. Hence, don't let the refurb get out of hand. Other than that they are a great, no-nonsense, all metal machine.
    Mf
  6. #6
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,578
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Good luck, JT! Keep us updated. I'm particularly interested in how your restoration goes as I am starting to dig into a newly acquired B5100D.
    Jim
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  7. #7
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    Looks like an interesting project. I know what it's like when looking for used engine parts, they aren't cheap. Good luck in your search!
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, Bobcat landplane ,4 in 1 bucket, Pallet forks
    2005 John Deere L118
    42" deck, bagger
  8. #8
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    I love those factory rear wheel weights. If you decide to part it out let me know.
    Seroiusly; You may be able to purchase another b7100 with a better engine for less than the rebuild on yours. I see them on craigs list from time to time. You could build one from the parts of 2 then sell or keep the remaining parts for spares.
    I love my B7100.-- looking for factory rear wheel weights.
  9. #9
    Join Date
    Sep 2011
    Posts
    95
    Boone N.C.
    Got my head, block, and crank to the machine shop yesterday. Good news so far. The cylinders are good for a .5mm bore and the crank will just get a polish. Ordered 675.00 worth of parts from Messicks just to get the machine work going and put the bottom end back together. Thankfully I obtained this tractor very cheap on a NC sealed bid so I have a lot of room to spend before I exceed the value. Hopefully I will have a like new tractor for the same money that I would have paid retail for one then had to make repairs. As for the wheel weights, the tractor has front and rear factory weights. With the FEL being plenty of weight for the front I am considering not using the fronts if the restore continues. The tires have never been loaded with fluid so my wheels should be in good condition. Spent 4 hours washing engine parts spic and span to prepare for a restore paint job as I re assemble. Will have to get the engine going before I will know what else needs repair besides the charging system which was the reason for the tractor being taken out of service.
    NHTC40A 16LA FEL
    CubCadet 1554
  10. #10
    Join Date
    Oct 2005
    Posts
    1,975
    New Hampshire, USA
    Kubota B6100
    Cool thread. I have a B6100, these little orange beasts are really tough.
    Mike
    B6100 w/ power steering - link below
    http://www.tractorbynet.com/forums/k...has-power.html
Similar Threads
  1. Geothermal Heat Pump Project
    By techman in forum Rural Living
    Last Post: 12-31-2014, 01:43 PM
  2. Holder tractor restore project.
    By hinks61094 in forum Projects
    Last Post: 04-14-2010, 03:19 PM
  3. B7100 Replacement.
    By JSF in forum Kubota Buying/Pricing
    Last Post: 02-21-2007, 08:38 PM
  4. Scrape Blade Project
    By Pooh_Bear in forum Build-It Yourself
    Last Post: 03-09-2006, 07:10 PM
  5. Analog Tach for B7100
    By RickNC in forum Kubota Owning/Operating
    Last Post: 07-30-2002, 02:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
