Kubota BX24 Injector pump problem
   / Kubota BX24 Injector pump problem #51
Thats unusual, the first I've heard of a BX main injection pump failing. Kudos to you for ignoring all of us that didn't think that was your problem. Just a pure guess on my part, but maybe you got a little water and shut it down at the exact moment it hit the pump, then it sat for a period of time and did its damage.
A couple of other thoughts. Can you move the lift pump or should it be near the tank like it is from the factory? I don't know the answer to this question.
I wouldn't mess with treating your fuel. Get one of those Mr Funnels and that will catch the water.
   / Kubota BX24 Injector pump problem #52
Thanks for updating us! Please let us know if you rebuild, what they find.
Deano
   / Kubota BX24 Injector pump problem #53
Another thought- On mystery oil website says its for lubrication in diesels, but doesnt say a word about water printed on website. power service does though..
   / Kubota BX24 Injector pump problem #54
Have you had the BX from new?
Sean
   / Kubota BX24 Injector pump problem #55
UPDATE:
Injector pump is bad and needs to be rebuilt. Internal water corrosion....
History:
The tractor is a 2006, it has 980hrs always garaged and the Kubota fuel filters have been replaced every year as well as air filter. Also used Marvel Mystery Oil religiously (recommended by local dealer)... Never used Biodiesel either.
Might have had some bad fuel at one time, I really don't know why this has happened..It's not like the tractor was ever sitting there unused for more than a few weeks.
What I know now:
- If you see fuel squirting out of injector pump outlets, it doesn't mean that the pump is good. Hook up one (working) spare injector to one line and see if you get some spray. If not. Then the pump isn't working right.
- I am replacing the original fuel filters with better ones and will use water prevention additive.
- I am also relocating the electric fuel pump in engine compartment. Too much of a pain to access (nothing to do with current problem tho)..
-New injector pump cost $860 + tax. Rebuilt cost is between $350 to $800 depending on damages.
Hello Fred,
Sorry to hear about the injection pump :(, AAAYYYY CARAMBA LUCY!!!!!
Candidly it is better to buy the new pump.
I would contact Foley foley engine and purchase the mechanical lift pump for this engine-yes they do have one that is driven off the engine drive train.
In for a penny in for a pound, as you have to replace/rebuild the injection pump I would strongly suggest that you install a Racor diesel fuel filter to prevent any water from entering the injection pump-between the fuel centrifuge and the cartridge fitration it stops 100% percent of the water by expanding to the point where it totally blocks the flow of fuel and the motor dies-its cheap insurance for sure as a 2 micron filter will filter out thousands of gallons of fuel before it needs replacing or water totally clogs the filter.
All I can tell you is they work and I have a Racor centrifugal filter on my kerosene tank and I know I have no problems with fuel now and will not have any problems with the boiler in the future because of crap and water in the kerosene fuel.
I would replace the fuel tubing with the Racor Reinforced Fuel Tubing as well as it(thr old tubing) will collapse on you due to the pressure gradient created by the vacuum of the electric pump.
   / Kubota BX24 Injector pump problem #56
I guess it's time for me to post a picture or two of my Racor fuel filter installation... Mine is just outside the frame of the tractor on the left side and just a bit in front of the floor pan on my BX-25. I was able to relocate the lift pump to between the Racor and the injector pump without messing with the wiring. I also left the original filter in engine compartment between the lift pump and the injector pump to protect the injector pump in the event that lift pump fails as suggested by Neil Messick. So..., Fuel tank, Racor, lift pump, factory fuel filter, injector pump. It is my understanding that (if the tractor has one) that it is best to have the lift pump after the Racor fuel filter so you do not promote emulsification (think mixing) of the fuel and any available water. I'll plan to take the photos this weekend when I'm out switching from leaf collecting to snow plowing mode... :thumbsup:
   / Kubota BX24 Injector pump problem #57
Yay!!!!!
I love it when a plan comes together!!:thumbsup:
   / Kubota BX24 Injector pump problem #58
The indirect injection fuel nozzle allows fuel to pass with no, I repeat no restrictions!!!!! :
This is not true on my Ford 1910. The dealer tested my nozzels in a unit that measures the pressure at which they crack open.
On a system like the 1910 if the injector pump is weak the injectors will not open. I know this from experience.
I Don't know if this is true on Kubota's.
   / Kubota BX24 Injector pump problem #59
I would agree with you.
Kubota is the same.
Sean
   / Kubota BX24 Injector pump problem #60
OK, here are a few photos I took a while ago. The first is the way I plumbed all the new stuff and the second is the filter installed on the tractor. The lift pump is behind the new mounting plate for the filter and toward the front of the tractor. I can try to take a pic of that if anyone needs it. The new mounting plate required no new holes in the frame. The bolt that is in front of the filter goes through the hole that was in the frame for either a steering or fuel line clamp. (I'll check that later). The small one near the top left corner of the mounting plate is a clamp that grabs the top edge of the frame. The wire for the fuel pump runs just under the fan shroud (I made a little holder to keep it there) and to the re-located pump. No more getting under the tractor and taking off the skid plate to change the fuel filter!:D
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
500 Gallon Fuel Tank with Pump (A55852)
500 Gallon Fuel...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
