Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Veteran Member canoetrpr's Avatar
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
    Default Re: Loud squeeeek noice on my new M7040...
    I haven't had anything of this nature Sam. I do recall a thread here where someone with this model had some unexplained noise related to the hydraulic lines.
    I'll try to search for that.
    Current: Kubota M7040 cab, hydraulic shuttle, Kubota M20 loader (made by ALO), LandPride RCR1872 rotary cutter, Horst bale spears & forks, Woods HB72 box blade, Kodiak 7' rake, Walco cultivator, chain harrow, Meteor 74" pull style blower
    Traded: Kubota L3400, LA473 HST (300 hrs), and various attachments
  2. #12
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    Sam, here is the thread I was referring to.
  3. #13
    Gold Member samofsweden's Avatar
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Quote Originally Posted by canoetrpr View Post
    Very kind of you helping me out Canotrpr! Well they talked about "clunking sound" I dont have that sound. First time I heard "my sound"it was when I shot of the tractor for the first time, as the engine stalled the squeek sound came just before the engine stopped turning.
    It really sounds like hydralic sound, the sound comes from the area underneith the foot-area.
    2 Kubotas, one BX24 and one M7040
  4. #14
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,921
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Sam are you familiar with how the hydraulics sound like when they are used beyond their limits and squeal? Is it the same/similar?
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  5. #15
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Quote Originally Posted by samofsweden View Post
    Ok Tom I will have that in mind.
    This might sound crazy....but I read that the M7040 are turbocharged and my manual says "check turbocharger every 3000hours" but I dont have any turbocharger on my M7040....The tractor are from 2009.
    U sure about that?Loud squeeeek noice on my new M7040...-turbo-close-up-jpg
  6. #16
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Default
    Yepp no turbo! Well it seems to work very well without... strong and responsive on the throttle. But I miss the turbo wissle.
  7. #17
    Platinum Member nspec's Avatar
    Join Date
    Dec 2007
    Posts
    624
    Southern Rhode Island
    Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
    Not sure of the years, but that tractor was made without a turbo to meet the tier II emissions standards. It got the turbo to meet the interim tier IV.
  8. #18
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,811
    MA
    L5450, L48, L3250, L345
    Sam - Is the transmission in neutral when it makes the noise ? Is the shuttle in neutral? Next time it makes the noise try pushing the clutch pedal to see if the noise is affected. If there is no effect, try shifting the shuttle into forward or reverse (with trans still in neutral). Finally, put the transmission in a gear and then engage the shuttle in forward or reverse. If any of these affects the noise it should narrow it down.
    L345, L3250, L48, L5450, never enough attachments
  9. #19
    New Member
    Join Date
    Dec 2012
    Posts
    15
    Pa
    Kubota M7040
    Default
    Quote Originally Posted by rbargeron View Post
    I know this is a very old thread, but my new 7040 appears to be doing the same thing. I wondered if Samofsweden had found out the cause. It is a very loud, high-pitched screech that only occurs when the tractor is warmed up and only in idle to half-throttle. Increasing the throttle makes it go away. To answer rbargeron, none of those things seems to affect it. Because it is so loud,it is difficult to isolate, but it kind of seems like it is coming from the front of the engine. It doesn't sound like a loose belt noise.
    So now I have two strange noises coming from my new $35000 machine. I'm glad there is a warranty...
  10. #20
    New Member
    Join Date
    Dec 2012
    Posts
    15
    Pa
    Kubota M7040
    Default
    Funny story - I got my 7040 back from the dealer yesterday. I had told them what I said here - basically a very loud screech at idle. First thing I noticed was that it was idling higher - around 1000 rpm. I started to use it and, what do you know, as soon as it got up to operating temp, it began screeching. So, problem not fixed. Called the dealer and spoke to the mechanic. I asked him what he had done. I kid you not, his solution to the problem was to increase the idle speed! "Well, it made the noise go away", he said (except it didn't)
    I know many of you have dealers that you like. I, for one, am regretting giving these goofballs my business (there have been other very unsatisfying interactions with them in the very short time I have had this tractor.)
    Another thing I discovered yesterday. If it is screeching, it goes away if I put the shuttle in forward but shift the gear shift to neutral. That is what I ended up doing yesterday when I had to keep it idling for more than a few seconds. Is it possible that there could be some kind of hydraulic relief valve that is staying open?
Similar Threads
  1. Help me making a final decision L4740 vs M7040
    By canoetrpr in forum Kubota Buying/Pricing
    Last Post: 07-05-2014, 07:09 AM
  2. Traction IH-574 1976 Hydraulic Noise Very Loud
    By elsmootho in forum Owning/Operating
    Last Post: 09-01-2011, 06:35 PM
  3. M7040 Weight
    By Rancher Ed in forum Kubota Owning/Operating
    Last Post: 05-24-2011, 09:06 PM
  4. larger pump capacity on M7040
    By jegenrieder in forum Customization
    Last Post: 04-23-2011, 11:05 AM
  5. What size cutter for a Kubota M7040?
    By Country1 in forum Attachments
    Last Post: 02-17-2010, 09:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
