Loader installing hooks on fel
   / installing hooks on fel #1
mkfriel2
Member
WV
Kubota bx2660
What is the best way to add hooks to my fel. Welding or drill a hole and use clevis style.
   / installing hooks on fel #2
I plan to buy some weld on hooks and weld them to a plate which I will bolt on the loader bucket.
just cann't seem to find bolt on hooks in ontario. might have to order them.
   / installing hooks on fel #3
Weld only... much stronger.
   / installing hooks on fel #5
   / installing hooks on fel #6
I did the same as the previous post except I turned the angle iron around 180 which closes the back of the bucket. 2x3x1/4 angle. This also gives the top of the bucket more srength. 5/16 hooks on each end and 3/8 in the middle.
   / installing hooks on fel #7
Ken's Bolt On Grab Hooks
Kennyd sells them, Not sure if he ships to Canada.
I think with the bolt on there would be more options to make it as durable as possible, thru the use of top and bottom plates etc, if necessary.
JB.
   / installing hooks on fel #8
I see that you have a BX2660. If you are looking for a different option other than welding or drilling a hole, you may be interested in what BXpanded has to offer Bucket Hooks. They mount and dismount in seconds. Attached is a picture of mine along with their brush forks.
   / installing hooks on fel #9
Those look great, I went to the website but still can't figure out exactly what holds them on. Do they wedge themselves in behind the top edge of the bucket?
   / installing hooks on fel #10
Heres mine. Philip.
Zero Turn Mower (A59231)
Zero Turn Mower...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
Westendorf 400 bu Gravity Wagon (A59814)
Westendorf 400 bu...
