Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Member cougar21300's Avatar
    Join Date
    Feb 2012
    Posts
    30
    Tax free NH
    Kubotas L5240, B7800, KX121
    Default Re: L3800 50 hour service
    Red Sox,
    Also remember at some point to check the tension on your fan belt to make sure it's still snug. It will stretch in a bit from new, especially once the weather warms up
    Kubota L5240HST, B7800, & KX121
  2. #22
    Join Date
    Apr 2011
    Posts
    126
    Central Massachusetts
    L3800 HST
    A good tip to add to my checklist.
    L3800 HST, Landpride 72" rotary cutter, Wallenstein BX42 chipper, FEL, BH77, 42" pallet forks
  3. #23
    Join Date
    Nov 2011
    Posts
    104
    Where is that oil fill point on the valve cover for a L3800? I looked today but didn't see it.
    Thanks.
    Kubota L3800HST w/LA524 Loader
    Land Pride Medium-Duty Cutter (RCF 2060)
    Armstrong Box Blade (BB-05)
    Rhino Post Hole Digger (L200)
  4. #24
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,734
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by Rail Dawg View Post
    Thanks.
    Its on the side, just up from the dipstick. Hey there are a lot of good thread on here about methods to change the hydraulic and hydro filters without loosing too much fluid.. I used the vacuum cleaner method but it put fluid spray into the vacuum. Another method is the park on a steep hill sideways with intended filter up hill. I havent tried this. Other method is just be darn quick.. Good luck and get back to us if you need anything..
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  5. #25
    Join Date
    Apr 2011
    Posts
    126
    L3800 HST
    Hey Rail Dawg, did you do your 50 yet and if so how'd it go?
  6. #26
    Bronze Member ritschner's Avatar
    Join Date
    Aug 2010
    Posts
    75
    Burnet, TX
    Kubota L2800 HST
    Thanks.
    On my 07 L2800 it is right behind the radiator hose outlet on the front right side of the valve cover. It is recessed a little.
    Attached Thumbnails Attached Thumbnails L3800 50 hour service-0304120815.jpg
    2007 L2800HST, R4's, Rear 3-Point Lever, LA463 FEL W/Shortened Loader lever, Rhino 160 mower, Armstrong Ag box blade, Armstrong Ag rake,
  7. #27
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    2,781
    Nova Scotia
    Kubota L3400DT
    Quote Originally Posted by ritschner View Post
    On my 07 L2800 it is right behind the radiator hose outlet on the front right side of the valve cover. It is recessed it little.
    I wish mine was there, it's a PIA having it on the side of the engine where it's harder to get at with a full jug of oil.
    Sean
  8. #28
    Join Date
    Aug 2010
    Posts
    75
    Burnet, TX
    Kubota L2800 HST
    Mine also has the side fill along with the valve cover fill. I did not find the valve cover fill until just before the 300 hour service so I know what it is like to add oil especially with the loader attached. I was a nice surprise when I found the valve cover fill. I have not looked at the other L-series to see if they have the valve cover fill.
  9. #29
    Join Date
    Nov 2011
    Posts
    104
    Quote Originally Posted by redsox1 View Post
    I did my 50 yesterday and holy cow what a mess I made! It's all done and cleaned up now but next time I'm going to have a better way to catch oil.
    What surprised me is the roughly 1-2 quarts of hydraulic fluid you lose when changing the hydraulic oil filter. No wonder guys use a shop vac..... Even when I went as fast as I could the fluid gushes out pretty quick. Be ready!
    The other lesson was removing the engine oil dipstick when draining oil. It took me 5 minutes of oil barely draining out before I pulled that stick out. It flowed great after that.
    Next time I'm going to have a big flat plastic catch basin and lots of old rags. That and my shop vac and it should go a lot better.
    This thread did help a lot.
    Take care!
  10. #30
    Veteran Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    1,947
    Northern CA
    Take care!
    Next time you will be draining all of the fluid so it really won't be that messy. Probably should have done it this time despite what the manual says. My opinion - stated many times.
    A washtub from Tractor Supply or a feed store works great for catching large amounts of fluid.
    You can also remove the oil filler cap for a better drain. You have to remove it anyway for the fill-up.
Similar Threads
  1. B2920 is in for it's 50 hour service
    By taborekle in forum Kubota Owning/Operating
    Last Post: 09-04-2009, 05:09 PM
  2. 50 hour service question + manual needed for B7610
    By jas67 in forum Kubota Owning/Operating
    Last Post: 06-23-2009, 08:10 PM
  3. B2620 50 Hour Service
    By Botabill in forum Kubota Owning/Operating
    Last Post: 05-20-2009, 08:24 PM
  4. 50 Hour Service Passed With Flying Colors
    By Jimsntcrz in forum Kubota Owning/Operating
    Last Post: 12-09-2006, 11:57 AM
  5. BX24 -- 50 Hour Service Checklist
    By lovemywoods in forum Kubota Owning/Operating
    Last Post: 11-12-2006, 06:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
