Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Jan 2012
    Posts
    10
    Grand Rapids, Michigan
    Kubota M7040 hydraulic shift and cab.
    Default M7040 Third Function
    A few months ago we bought a new m7040 with a cab, FEL, and third function. The dealer didn't have the parts in stock for the third function so we waited until the 50 hour service to have it put on. We just got it back yesterday and it seems like the installation was half assed.
    Power wire to the right side of the seat:
    Wires from on / off switch
    Wires / cables coming through the bottom of the floor
    Bundle of zip tied and exposed wires a foot away from the rear tires..
    Is this just normal?
  2. #2
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,646
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default Re: M7040 Third Function
    On my 9540 open station they did a much nicer job concealing the wires. I'd take it back if it were mine.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  3. #3
    New Member
    Join Date
    Jan 2012
    Posts
    10
    Quote Originally Posted by DT86 View Post
    How did they route them? I'll probably just change it myself. Also, is just about all the wires and hoses around the engine held on by zip ties?
  4. #4
    Join Date
    Dec 2010
    Posts
    1,646
    SW VA
    I was surprised when the guys in the shop said it would take them the better part of a day to install mine. Apparently it was worth it because I haven't noticed much of the additional wiring required to run it.
    The wires that come out of the green on / off switch are zip tied to the joy stick and they run into the rubber boot and through the console. Other than that its a mystery to me. I'll try to look and get a better idea on how they concealed all the other wire loom.
    As for the under hood wires and what not I'll check on that also.
  5. #5
    New Member
    Join Date
    Jan 2012
    Posts
    10
    Pics would be nice if you don't mind. Thanks
  6. #6
    Join Date
    Dec 2010
    Posts
    1,646
    SW VA
    Ha ha alrighty then. The GF has the new iphone and it has a pretty nice camera so it shouldn't be a problem.
  7. #7
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,797
    Canada
    B3200, L5740,
    The third function install is quite involved. I am sure it would take one man most of the day to install and that is if he knows what he is doing.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  8. #8
    RFB
    RFB is offline
    Join Date
    Jan 2006
    Posts
    871
    West Central Idaho
    Grand L5740HSTC, Kubota LA854 FEL with QA Bucket
    Default
    Sir,
    I do not how much the GL5740HSTC differes from your model, but attached is a photo of my 3rd function as it was upon delivery.
  9. #9
    Join Date
    Dec 2010
    Posts
    1,646
    SW VA
    Quote Originally Posted by colby587 View Post
    Here goes....
    Ok, right here where I added the yellow arrow there was once a Zip Tie. It sat snug it the ring and held the wires to the boot. I removed it when I had to lube up the loader linkage and lost it. The cut in the boot where the wires run in is a one-off custom job.
    In the top center of this pic you can see the wires and the loader linkage coming through the floor. The wiring runs into a very factory looking wire loom and goes towards the front of the tractor.
    Due to the huge metal guard I can't tell where exactly where anything ends up going.
    I would say that the guys in the shop must have done a very good job since I can't even figure out where the additional wiring is.
    As for under the hood and everywhere else on the machine, yes it seems like several Zip Ties are used. I'm not sure that is a bad thing though. I have some Zip Ties in the garage with a 80lb work rating. They reusable if you take two extra seconds to un-do them properly and easy to replace if you don't!!
  10. #10
    New Member
    Join Date
    Jan 2012
    Posts
    10
    Thank you I'll try doing something like that. Now I just have to get some lines made for my grapple and some flat face fittings. I just fed the animals and the tractor had two small puddles under it, one is from a line they put in and the other is from the front hydraulic steering cylinder. Hopefully the cylinder doesn't need to be repacked...
Similar Threads
  1. Loader Kubota FEL with 3rd Function Valve
    By rjkobbeman in forum Kubota Owning/Operating
    Last Post: 01-26-2012, 12:14 AM
  2. Replies: 18
    Last Post: 01-23-2012, 01:29 AM
  3. Regarding 3rd function valve sticking
    By brocas in forum Kubota Owning/Operating
    Last Post: 09-22-2011, 08:21 PM
  4. Help me making a final decision L4740 vs M7040
    By canoetrpr in forum Kubota Buying/Pricing
    Last Post: 09-22-2011, 10:16 AM
  5. John Deere 4600 - no bucket tilt function??
    By Willus in forum Hydraulics
    Last Post: 06-13-2011, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
