top this tree service
- Joined
- Jan 30, 2012
- Messages
- 2
- Tractor
- kubota L4150
Hi my name is Harold. I have a Kubota L4150. My issue is that my tractor seems to be losing pressure when under a load. For instance if i was trying to push something or pull something, the machine would seem to pop out of gear. but the gear select would be in the correct position. It feels like a pressure relief valve is kicking or something of that nature. i Had just changed all the fluid to the kubota super udt. did not help. the back hoe works, the bucket does everything, up down tilt everything. But when it comes to moving forward or backwards it just wont move under any kind of load at all what so ever. I was reading in the manual about a pressure relief that you can increase pressure with shims. ANY ONE HAVE ANY CLUE?!?!?!
It is a kubota 4wd L4150 with hydraulic shuttle.
