Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 44
  1. #1
    Gold Member
    Join Date
    Jul 2003
    Posts
    267
    Kingsville, MD
    B2150
    Default How to Jack up A tractor?
    Hi. I've got a B2150 and need to remove my Front and Rear wheels to take them to have new tires mounted.
    Where is it safe to put a jack under the rear to jack it up to remove the wheels ?
    I have a FEL and firgure I can use it to lift the front while I remove the front wheel and then lower the front onto some blocks with lumber.
    But the rear concerns me a lot more as it is larger and heavier and I don't know where the proper lifting/jacking point is on the axle.
    Any suggestions ?
    Thanks, Tim
  2. #2
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: How to Jack up A tractor?
    Hopefully this will help you. change | Gempler's
    The PUPIL who does not surpass his Master, fails his Master.
  3. #3
    Gold Member
    Join Date
    Jul 2003
    Posts
    267
    Kingsville, MD
    B2150
    Quote Originally Posted by creekbend View Post
    creekbend,
    Yes... that does help.
    THANKS !
    Tim
  4. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Kubota L4400
    One other suggestion and advice: Please work safely and do you best not to get in a rush and think things over before you do them.
  5. #5
    Join Date
    Nov 2004
    Posts
    205
    MN
    BX 2200
    Only thing that bothers me here is that an "old" SOLID tractor with a lot of cast iron in the rear axle was used as a demo. What are the concerns with those tractors with a lot of cast aluminum housings for the rear axle? And none to thick aluminum I would bet at that. I am always a little nervous about where to best support when jacking or blocking.
  6. #6
    Gold Member
    Join Date
    Jul 2003
    Posts
    267
    Kingsville, MD
    B2150
    Agreed. Words to live by.
    Thanks for the caution... I'll take my time and think each step through.
    Tim
  7. #7
    Join Date
    Sep 2011
    Posts
    140
    South eastern Pa.
    kubota B26
    I would only jack from steel frame members.
    MAKE sure you put jack stands under. DO NOT depend only on the jack.
  8. #8
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    16,565
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Parking brake on,if gear tranny use low,block rear tires,lift tires just enough of the ground to slide tire off...great advice given by others.
  9. #9
    Gold Member
    Join Date
    Jul 2003
    Posts
    267
    Kingsville, MD
    B2150
    Good advice indeed.
    It's a scary proposition to jack something up this heavy... even changing a car tire makes me feel uneasy.
    As I jack it up, I'll be sure to place Blocks/Lumber under the axle and lift only as high as necessary to get the wheel off.
  10. #10
    Join Date
    Jul 2009
    Posts
    1,793
    IL
    B2710
    I put floor jack under part where the drawbar is attached and jack up whole rear end. Tractor will be free to rotate around attachment point of front axle once both rear wheels are off the ground, so don't depend on this to hold it up safely. Jacking from the center makes it easy to block both sides and lower it down on the blocks. If you jack out by each wheel, there's no room to put the blocks in. I leave the jack snugged up under the drawbar with a little force on it, just in case one of the blocks fails you've got another line of defense to help hold it up long enough for you to run.
    Kubota B2710, John Deere X738 snowblower, Toro Zmaster ZTR, King Kutter bush hog, New Idea manure spreader, Swisher trail mower.
    Lincoln Square Wave 200, Lincoln 225 AC/DC, Harris Oxy/Ac.
Similar Threads
  1. Dual Brakes on an HST tractor
    By Lockport in forum Owning/Operating
    Last Post: 07-06-2011, 11:58 AM
  2. Tractor Failed To Start/White Gunk in Fuel
    By dmccarty in forum Oil, Fuel & Lubricants
    Last Post: 06-30-2010, 08:54 AM
  3. Jack for tractor?
    By Royboy in forum Owning/Operating
    Last Post: 03-03-2010, 05:48 AM
  4. Any Final Thoughts
    By dlroy101 in forum Kubota Buying/Pricing
    Last Post: 12-07-2005, 12:40 PM
  5. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
