Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    17
    Michigan
    09 Orange L3400 HST
    Default Spanning Wrench
    I looked high and low for a spanning wrench to adjust my Left Arm Leveling Assembly, instead of using the hole at the end of my adjustable wrench. I was tired of the wrench slippting off the end of the metal rod and busting my knuckles from time to time. Sometimes, pain is a great prompter of thinking, so I built one out of a piece of 3/8 re-bar.
    It works quite well, and can be reversed for raising or lowering my blade in the dead of winter, expecially when I adjust the angle of the blade to avoid tearing up my gravel driveway.
    Attached are a couple photos if you are interested.
    Attached Thumbnails Attached Thumbnails Spanning Wrench-2012-02-01-006-jpg   Spanning Wrench-2012-02-01-009-jpg   Spanning Wrench-2012-02-01-011-jpg   Spanning Wrench-2012-02-01-005-jpg
  2. #2
    Join Date
    Oct 2010
    Posts
    1,380
    NHtd75
    Default Re: Spanning Wrench
    Clever idea that works.
  3. #3
    Join Date
    Feb 2009
    Posts
    1,061
    CA
    2002 New Holland TC40S
    What a simple, effective and economical answer to an age old problem!
    Even though I have top and tilt cylinders, I did keep and moved the adjustable arm assembly over to the other side so I still have a need for your spanner.
    Good job.
  4. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Innovative.
    The PUPIL who does not surpass his Master, fails his Master.
  5. #5
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    I used a piece of re-bar for mine too, but I drilled a hole in one end that slips over the rods on the adjuster.
    Sean
Similar Threads
  1. Ridgid Pipe Wrench Warranty Problems
    By LD1 in forum Build-It Yourself
    Last Post: 12-28-2011, 03:30 PM
  2. Brief Rant about Craftsman
    By Iplayfarmer in forum Craftsman / Sears
    Last Post: 03-06-2009, 12:02 PM
  3. 1925 / TC33 etc. Hydro Filter Wrench
    By AlanB in forum New Holland Owning/Operating
    Last Post: 06-23-2008, 04:58 PM
  4. Affordable Center Pivot Nut Wrench
    By MossRoad in forum Power Trac
    Last Post: 10-02-2006, 02:12 PM
  5. Air Impact Wrench
    By Anonymous Poster in forum Parts/Repairs
    Last Post: 05-31-2003, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
