jdonovan
Gold Member
Any of you fellas have the self leveling valve on your loader and does it work well?
Have one on my M59. It works very well when handling things on pallets, or anything else you want to stay level as you lift.
Are you using forks that slip onto the bucket edge, or a fork attachment that replaced the bucket? Slip ons move the weight very far out and make it harder to lift.
You may also want to see if your pallets are 'long tons' 2200lbs, or 'short tons' 2000 lbs. I've seen a both called a 'ton'. Also don't forget to add packing materials + skid to the weight calculation.
the LA1153 has a lift of 2,326 lbs at the bucket center... which is probably only 1 foot from the pins. A standard 48x40 pallet means your load center is a minimum of 2 feet from the pins. Also that lift capacity generally DOES NOT include the bucket weight (or pallet forks).
All said I would NOT expect that tractor/loader combination to reliably handle 1 ton loads from the specs. You might be able to just barely lift them, but not to full height, and not with any kind of extra reserve to deal with a slightly over loaded pallet.
I lift a ton of feed on pallets off my truck everytime I go pick up feed,usually un-load it with my M5040 or M7040,never any problems.They are usually in the bed of truck or on trailer,I usally just pick them up high enough to get off trailer but never have tried to pick to them up any higher than that cause I usually lower them down as soon as they get off,and put them in barn..
Good to hear your loader working well for you.
Do you have an 1153 loader, and are the pins on your main lift cylinders in the higher position?
Thanks.
Nope, had one on our Case and didn't like it; maybe if I was a doing a LOT of pallet work.
what was your reason for not liking. Seems like a super idea but I have never had anything to do with hydraulic self level.
