Results 11 to 20 of 32
04-28-2012, 11:15 PM #11Elite Member
- Join Date
- Apr 2008
- Posts
- 4,897
- Location
- Somerset, Ky
- Tractor
- currently own F3080 F3080 B2620 FEL/BH RTV1140
Re: greenhorn with orange dream machine
Congratulations on the fine Orange machine and I to enjoyed your story of conquering those long lasting problems that are now history and a memory.
2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425
).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
04-28-2012 11:15 PM # ADS
04-29-2012, 07:05 AM #12Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,854
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Very nice equipment indeed and good write up.
04-29-2012, 07:45 AM #13Silver Member
- Join Date
- Jan 2012
- Posts
- 155
- Location
- SWFL or WNC
- Tractor
- Kubota BX2660 BX2230
Nice story of your new serious tractor. Seeing your Dodge in it's fine condition means you will keep the Kubota in top shape too.
04-29-2012, 08:26 AM #14Gold Member
- Join Date
- Dec 2006
- Posts
- 318
- Location
- Disputanta, VA
- Tractor
- 2007 Kioti CK20 & 1981 Iseki TU1700
You have nice equipment and a very nice yard. Now time to get to work on where you removed your pet rock.
Eddie08 Dodge (Cummins) 2500, 2007 Kioti CK20, FEL, Finish Mower, 4' Howse Bush Hog, Landscape Rake, 52" Woods Tiller, 5' Rear Blade, 4' Box Blade, 5 horses, 2 dogs, 1 fat cat, 1981 Iseki TU 1700 for grass mowing.
04-29-2012, 09:13 AM #15
Great story, great machines you have there
Joy is having the tools you need and needing the tools you have!
Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
04-29-2012, 09:32 AM #16
Great read, and I like the truck!
04-29-2012, 09:53 AM #17Bronze Member
- Join Date
- Jun 2002
- Posts
- 53
- Location
- Northwest Louisiana
- Tractor
- 2011 Kubota BX2360
great story...thanks for sharing!
2011 BX2360; 60"MMM w/mulch kit
LA 243 FEL; Drawbar
2000 Stihl 026 Pro Chainsaw
Chocolate Labrador Retriever
04-29-2012, 10:13 AM #18
Congrats. Great looking tractor.
04-29-2012, 11:21 AM #19Bronze Member
- Join Date
- Feb 2012
- Posts
- 59
- Location
- Finger Lakes, upstate NY
- Tractor
- Kubota L3940HSTC, LA724, BH92
What a pleasure to enjoy your comments, compliments and good wishes on a Sunday morning, (or anytime).
Yes, the D100 Adventurer is a few steps lighter in color. It was a 1978/one-year-only color called Sunrise Orange, hence the truck's name. It's substantially older than the 'Bota; let's pretend it's just faded. (But it's not!)
As far as the story goes, glad you enjoyed it. You were owed; folks here have been very good to me.
So, an update or two:
The larger rocks I am using to build up the dam in our creek. Eventually, I want to be able to drive across the dam, (which will preclude having to drive around to the other side using the public road). I'm creating a chute for the water, hoping to be able to use it to generate electrical power with a hydro-turbine. The final rock I extracted would classify as a small boulder, and was right next to our long-established fire circle. This was yet another drive-around mower/truck issue. The part sticking out of the ground was about the size of a large party punchbowl (inverted), but in the whole rock, in reality, is about 20% the size of a Volkswagen beetle. It was very rounded, with no edges to grab on to, and it took some doing to get it up out of its hole using the backhoe but I did it. Later that day, I removed the front loader bucket and installed the pallet forks, to get under, lift and move all of the newly-freed rocks to the dam. Or so I thought. Actually, the method worked well for all of the rocks except this one. It was too big to move, just plain too heavy! The Kubota's hydraulics simply wouldn't lift it, but learning the machine's limitations is an important part of this get-acquainted process. The rock looks like it is rose quartz maybe. (There is another even bigger one made of the same stuff at the far corner of our property. Both were brought here and deposited by the glacial movement, no doubt.)
Thanks for the weight spec estimate, magicheater. I was wondering!
gilbertmsg, always thinking ahead, sir! The ground craters, (there ended up being 4 of them, not counting the plumbing in the garden plot), are already filled and graded. Used the FEL to lift manageable carpets of live sod off of the proposed garden expansion, and re-sodded the wounds to heal them. (I'm not too good at this yet. Getting them about 5-6" thick, when what I want is more like 3".) A few more rains, a few more months, one would be hard pressed to recognize the rock sites.
I'm having fun. Wish you the same."Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
05-19-2012, 02:28 AM #20Bronze Member
- Join Date
- Feb 2012
- Posts
- 59
- Location
- Tractor
I'm at a little over 40 hours on it now - coming up on my first oil change. I finally got done with all the little backhoe chores, and decided to remove it and get on with the 3-point stuff.
I can see that one has to take operator's manual info with a grain of salt. The BH92 book tells you to remove the backhoe's mounting pins while the stabilizers are still 15" off the ground. (P. 17). But common sense prevailed.
Unfortunately, more than that was needed. It was at that point I noticed, (although it took me awhile to figure it out), that the dealership had installed the pins the wrong way for a L3940HSTC. They should both be installed from the inside. They installed them from the outside, and to pull them out, there's not enough room to do so; the inner sidewall of the rear tire won't allow them to clear. The dealer sent a guy out to take off the rear tires to get the pins out. It was an understandable mistake. I guess on many models, they are supposed to be put in from the outside. Also, the machine had been sitting there at the dealer, waiting for the R1s to show up - it had had R4s - and so the BH was already on when they put on the wheels/tires, and they never noticed the error.
Anyway, slight stutter but I finally got the 3-point on, and the Phoenix T10 tiller is poised and ready for action. It hits the dirt tomorrow."Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
Similar Threads
Had to take my bucket off for this machine hunting adventure...
By mjozefow in forum AttachmentsReplies: 0Last Post: 08-28-2011, 01:58 PM -
New machine headed back to shop for the 3rd time, I'm gonna go postal
By boogerman2000 in forum Kubota Owning/OperatingReplies: 16Last Post: 04-24-2008, 10:46 PM -
Gator XUV Evaluation (long)
By 519NASCAR in forum ATVs & Utility VehiclesReplies: 11Last Post: 02-04-2008, 07:47 PM -
Difficulty in deciding which machine to get
By bandit67 in forum Kubota Buying/PricingReplies: 24Last Post: 10-03-2007, 02:44 PM -
Going orange
By James in forum Kubota Buying/PricingReplies: 12Last Post: 04-08-2001, 09:59 AM
