MoreCowbell
I know there have been a lot of posts about the BX2350/BX24 abrupt reverse stop issue, but I don't think there has been a discussion about which specific part(s) were modified in the the current BX line to fix that.
Looking at the transmission part numbers and diagrams, both the old and new BX HSTs share the same part numbers for the vast majority of the transmission. When looking at the assembly for the HST pump and motor (labeled 060 and 100 in the diagram), those bear different part numbers. The Messicks site shows that the old pump and motor part numbers have been replaced by the new ones. It would seem that if the modifications to either of these was indeed the fix, someone replacing these in a BX2350/BX24 would see the issue resolved. Has anyone experienced that?
Both the pump and motor apparently work with the "Port Block Cover" casting (labeled D013) which houses a couple of relief valves that also have different numbers between old and new. However, I doubt the relief valves are the cause of the problem.
Anyway, I'm just curious as to whether anyone has identified the actual replacement part(s) that would resolve the issue. My understanding is that Kubota has not released this information. I assume they did not want to invite warranty claims if the issue was fixable with a part or two (these parts are rather pricey).
