Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Dec 2011
    Posts
    6
    Default BX25 First 50 hour oil change
    What a pain is the ars the oil filter is to remove, I put in Rotella synthethic oil, and the low idle is as smooth as a kitten purring, instantly. What a difference, also checked the front axle, and had to add a quart of udt, no leaks and it was off the stick completly, where did it go? Tomorrow I am changing the hyd filter and just adding makeup fluid, for the filter and fluid loss while cleaning the hst screen.
  2. #2
    Join Date
    Oct 2011
    Posts
    2,371
    Olalla WA, Kitsap Peninsula, West of Seattle
    Kubota BX25
    Default Re: BX25 First 50 hour oil change
    Quote Originally Posted by neatoooo2001 View Post
    Get one of those oil filter wrenches that have the 3 jaws and fit a 3/8 drive, goes right in the small hole and the filter comes right out. You can tighten by hand through the shroud hole. I know the manual says remove the shroud; but, no need to until you change the fuel filter under there. Maybe a small monkey could get their hands in there w/o but I can't. I am moving it to undernerth next to the fuel booster pump.
    Ron
  3. #3
    Platinum Member AStanton's Avatar
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    Here's what I use on my BX25. Put it on the end of a rachet wrench extension; it gets right in there.
    Attached Thumbnails Attached Thumbnails BX25 First 50 hour oil change-cap-style-filter-wrench-2-a
  4. #4
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,716
    Beaver Creek, Northern Michigan
    Kubota BX2360
    The front axles on BXs are notorious for being low on fluid at delivery. The design of the axle is such that most cannot be filled in one attempt. When you drain the axle fluid, which isn't a bad idea to do bi-annually, you can fill it with fluid (gear lube or SUDT) and it will read full.
    But I assure you, go operate the tractor for 6-8 hours and re-check it. It will have worked the air pockets out and it will read low. Very common situation with the BX and discussed here on many, many occasions.
    BP
    "Some chickens, some gardens and a Kubota."
  5. #5
    Silver Member bx2670's Avatar
    Join Date
    Nov 2011
    Posts
    121
    Pilot Mountain N.c.
    2013 Bx 2670
    I did my 50 hr service today well 45.4 and changed everything but air & fuel filter.Put Rotella T 15-40 wt in engine, SUDT in trans, Royal Purple 75-90wt in gear box of MMM and Lucas high performance 80-90 wt in front axel.I pulled plugs on everything sat nite and started filling sun after dinner.Mowed sun evening and everything went great ,don't know if it was my imagination or not but seemed more quiet and run better.I will try synthetic oil for engine next oil change
  6. #6
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    Make sure you check that front axle a couple of times. Sometimes they are a bear to fill.
    Deano
    Deano
    2006 BX24, 6' Modern Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!!, Agri-Fab drop spreader.
Similar Threads
  1. Synthetic Oil at first 50 hour service?
    By DieselDon in forum Kubota Owning/Operating
    Last Post: 03-31-2012, 11:05 PM
  2. Tips for 3x20's 50 hour change
    By Rob-D in forum John Deere Owning/Operating
    Last Post: 04-13-2011, 06:52 PM
  3. B3200 TLB 50 hour service question..
    By Chris86314 in forum Kubota Owning/Operating
    Last Post: 06-26-2009, 11:20 PM
  4. Is Amsoil API certified?
    By saparks10 in forum Oil, Fuel & Lubricants
    Last Post: 10-02-2007, 06:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
