Results 1 to 5 of 5
  1. #1
    Gold Member samofsweden's Avatar
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Default Pto clutch remove problem m7040
    Hi. Im hunting the sqeek sound on my M7040. A nice gentleman on TBN, Greg Hammerstein had the same problem on his kubota M7040, and Kubotas serviceman knew exactly was it was and removed this unit and behind he found metal shavings that creates this sqeek sound on idle when the oil is warm.
    Please if anyone know how to remove this please reply. Thanks
    Sam
    Attached Thumbnails Attached Thumbnails Pto clutch remove problem m7040-image-3059653387-jpg   Pto clutch remove problem m7040-image-2354010967-jpg
    2 Kubotas, one BX24 and one M7040
  2. #2
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Default
    Found the solution but havnt found any metal shavings well pieces of rubber gasket in the small hole of the relief valve...hmm... Well I dont know if thats the answer to the sqeek sound!?
  3. #3
    Join Date
    May 2010
    Posts
    90
    Default Re: Pto clutch remove problem m7040
    Hopefully it works. A good case for keeping clean the areas areound movable parts..
  4. #4
    Join Date
    Apr 2007
    Posts
    723
    Northern Lower Michigan
    Kubota B3030HSDC
    I have been wondering if you ever fixed that problem on your new tractor.Good Fortune!
  5. #5
    Join Date
    Oct 2007
    Posts
    290
    Kubota Bx24, 2007
    Ok ok. Today is a great day!
    Thanks to TBN and GregHammerstein here I finally got to kill the screaming sound of my M7040!
    (A few hours removing the rear wheel, fueltank and the ptoclutch cover)
    Feels like a new tractor
    Thanks Greg!
    /Sam
Similar Threads
  1. Ever Clutch Follow up
    By clinter36 in forum Kubota Owning/Operating
    Last Post: 04-15-2014, 08:52 AM
  2. How To Remove PTO Overspin Clutch
    By gurumanjohn in forum Attachments
    Last Post: 09-06-2011, 10:31 AM
  3. PTO clutch repair
    By FotonOwner in forum Parts/Repairs
    Last Post: 12-01-2010, 03:17 PM
  4. L48 PTO Clutch RPM Problem
    By ChompinBrush in forum Kubota Owning/Operating
    Last Post: 12-01-2008, 12:32 PM
  5. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
