rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,656
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I really don't know what happened, but I am guessing a cup seal caught the flow and thereby got reinforced.
But I really don't even know if it has cup seals in the cylinders. I don't know how it is piped. I don't know if it is in parallel (one piston side in parallel with the rod of the other cylinder, etc.) I used to tell folks that telling me what they don't know is not helping...so I will heed my own advice and stop right there.
I was wondering if I was talking out of my hat with my analysis, but I have found a hydraulic diagram that supports my theory buy searching "backhoe hydraulic diagram" on Google.
HYDRAULIC SYSTEM DIAGRAM (SERIAL NUMBERS 319995 THRU 342573 ONLY)
Compare that diagram to my comments earlier, and do tell us if it matches yours (vis a vis the swing cylinders only), if you don't mind.
Hey, Thanks for that hydraulic system diagram. What is that one for?
As for the series versus parallel swing cylinders. The M59 is similar to what you referenced. Near as I can tell, the M59 works the same way in that the piston side and rod sides of opposite cylinders are pressurized at the same time. Doing it that way doubles the force, moderates the flow, and probably makes it smoother....but does make it difficult to visualize how the swing could only be powered in only one direction no matter what happens with the cylinders.
I'm not that familiar with fancy construction equipment hydraulic systems, just with the older open circuit tractor type. In comparison with the basic one in that diagram you referenced, the M59 is much more complex. It is more sophisticated than anything hydraulic I've ever dealt with.
The backhoe controls alone have 8 or 10 hi-tech dual stage adjustable & expensive relief valves (all identical) which I've ever seen on a backhoe control. One for each motion. Plus several load checks for things like the stabilizer legs.
Instead of using a single big hydraulic pump with flow proportioning circuits, the M59 has completely separate additional hydraulic pumps for different hydraulic circuits - looks like three in all. Not counting the HST tranny. The swing system has its own separate hydraulic pump. All this complexity and mine doesn't even have the accessory rear hydraulic outlets. I'm glad for that! Just has the optional bucket thumb - which of course has its own control and associated relief valves.
They sure didn't spare themselves any complexity on the backhoe operation. In their defense, I'll say that the controls do have a very good "touch".
Thanks for all the help, rScotty
