Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Join Date
    Nov 2011
    Posts
    588
    Southwestern Virginia
    JD 5055E
    Default Re: I want a bigger bucket
    If you intend on ONLY doing loader work, would a skid steer work for you? The bucket is usually very large for the size of the machine. They are MUCH faster than a tractor doing loader work.
    However they do have down sides. Vision, ride, attachments are expensive, to name a few.
    Again if loader work in small spaces is what you need, that's what they were built to do.
    Bill
  2. #12
    Platinum Member allen in texas's Avatar
    Join Date
    Oct 2007
    Posts
    647
    Levelland, TX
    Kubota Grand L 5740, loaded R1's w/642 lbs cast weight, 854 loader
    James, the material I move doesn't fall into the category you speak of. I deal with dirt and sand, crushed limestone, recycle, (crushed concrete and asphalt mix, one inch or less) and gravel (also one inch or less). It is a simple matter to get a bucket full. Idle into the pile, curl and it's full but I see your point on the larger stuff.
    Bill, I plow, till, dig, scrape, mow, shred, spray...all the sort of stuff that you would do with a tractor and obviously way more than just loader work. A skid steer wouldn't fill the bill for me but I have looked at some of the skid steer buckets. And I got to see a couple of the new Kubota tracked skid steers last weekend. COOL!!
    I may change my mind and get a new rear blade instead. Mine is junky, floppy loose and wore out. (My blade I mean) I've wanted a new one for a long time and the money I would spend on a new bucket would go a long way toward the purchase of the blade
    This one in 7 foot all hydraulic...
    http://www.landpride.com/products/12...es-rear-blades
    KK 72" tiller Rears SPF 72 inch Flail, FL960 knives, Cammond BS72E 6 foot BB,
    HF Quick hitch, RBT3584 rear blade.
    assorted two and 4 row diamond bar equipment, all junky.
    20 ft Big Tex 70CH
    Maxey 14000# 16'x83" GN dump trailer
    Oliver 6241 3 bottom rollover moldboard plow
    I like straight furrows
    1960 model 102 Ford 14 inch two bottom rollover plow on my little L3240
  3. #13
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,063
    Somewhere north of Roseau,MN
    Fordson Major Diesel, Ford 1510, John Deere L111
    Bigger? You mean like this? It's home-made and was on the tractor when I bought it; I only added the grapple. It can get real heavy when fully loaded, but I love the huge capacity. I've never wished it was any smaller, as you can always dump a little material out if it's too heavy, and it has allowed me to grab and move some pretty large items that might be iffy with a smaller bucket.
    Joe
    Attached Thumbnails Attached Thumbnails I want a bigger bucket-102_3603.jpg   I want a bigger bucket-0512121301.jpg   I want a bigger bucket-0512121353.jpg   I want a bigger bucket-0518121539a.jpg   I want a bigger bucket-252083_1948189346054_1282194262_31881586_4234086_n.jpg
    Ford 1510
    Du-Al 105 Loader
    "The Thumb" Grapple
    Bush Hog RBC60 Rear Blade
    Woods HC54 Rotary Cutter
    Tarter 5' Heavy-Duty Hinge Back Box Blade
    Buhler Farm King Y600 Snowblower
  4. #14
    Join Date
    Nov 2011
    Posts
    588
    JD 5055E
    Quote Originally Posted by allen in texas View Post
    If you decide you want a SS bucket, try one first if you can. Most of them are lo profile, and are rather deep, (front to back). They work great on a Bobcat which has lots of breakout. Not so good on Ag. loaders.
    Because of the type of material your moving you may be OK. The best thing would be to try one first.
    Best, Bill
  5. #15
    Join Date
    Oct 2007
    Posts
    647
    Levelland, TX
    Joe, now you're gonna make me want a grapple. Does it EVER end?
    Oh, and it looks like you might need to prop up your over head fuel tank a bit.
    Bill,
    Good point on the breakout. I never thought about that. That's a lot of leverage with that long bucket. I did some more checking this weekend and I decided to keep what I have and get a new blade instead. I'll get a lot more use out of it.
    20 ft Big Tex 70CH
  6. #16
    Join Date
    Jun 2010
    Posts
    1,063
    Hah hah... Actually, that's a water tank. We had a dry spell and we really needed to water the garden. There's no way I was willing to purchase and fight with 500' of garden hose and I didn't have a spare pump, so I filled a tank I was saving for a sprayer project, attached 50ft of soaker hose, lifted it high as I can and let gravity to it's thing. Irrigation on the cheap!
    And, no, It never ends.
    Joe
    Ford 1510
    Du-Al 105 Loader
    "The Thumb" Grapple
  7. #17
    Join Date
    Jan 2012
    Posts
    224
    YARRA GLEN, Victoria 3775 AUSTRALIA
    Thinking of buying a KUBOTA MX5100
    i wish we had EverythingAttachments in Australia...its a very good site at it has everything you would ever need.
  8. #18
    Join Date
    Jan 2012
    Posts
    224
    I might have to become their agent...its crazy here...you cant find implements that easy..lol
  9. #19
    Veteran Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    2,388
    Bay Roberts, Newfoundland, Canada
    Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
    I wanted a bigger bucket for my 5740 BUT only to move snow. It's considered a light meterial bucket but I made a few mods to it. I wouldn't recommend using it for heavy meterial simply because the tractor wouldn't lift it.
    http://www.tractorbynet.com/forums/w...cket-mods.html
    ...Excellence is not just a skill. It is also an attitude...
    Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
    YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25DTLB With Wallenstein BXM32
    Kubota ZTR ZG 222 Z
Similar Threads
  1. Specs for new 3320
    By foggy1111 in forum John Deere Buying/Pricing
    Last Post: 06-24-2010, 07:52 AM
  2. Bigger bucket for Quick change on CT225
    By skyline in forum Bobcat Tractors
    Last Post: 06-24-2009, 08:22 PM
  3. Replies: 11
    Last Post: 03-26-2007, 10:22 PM
  4. Bigger bucket for KL130
    By gippolit in forum Kioti Owning/Operating
    Last Post: 07-05-2005, 01:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
