Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Feb 2012
    Posts
    74
    Finger Lakes, upstate NY
    Kubota L3940HSTC, LA724, BH92, RTV-X1100C
    Default Reverse tiller rocks gonna bust up my cab
    I'm running a reverse-tine Sicma (Phoenix) tiller behind my L3940HSTC. It's their extreme heavy-duty model T10R-66GE, (or, outside of the states: RCS/165). Both tiller and tractor work great. But the reverse rotation is kicking dirt and stones up onto and into the back of the tractor. Some of the rocks are surprisingly big. Every once in awhile, one wings forward so violently, I know it's just a matter of time before one takes out my small lower rear cab window - or worse, the large one. I can also see it causing other problems, with rocks getting jammed in the travel path of the 3-pt. up and down, etc.
    I've am already designing a guard to keep this from happening. (It doesn't appear that the maker has anything listed along the lines of such a guard.) But I just wondered if anyone else has had this situation with the reverse tillers, and what they did about it.
    "Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
  2. #2
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    Default Re: Reverse tiller rocks gonna bust up my cab
    post some pictures of tiller you have, and hooked up to tractor as well. you will more likely get a few more folks to respond if you do.
    there has been a few threads i remember seeing over the years of folks making different type of shields. but being able to see the actual tiller (top side) and under side of were you could mount something. and then hooked up to tractor. can really help folks visualize things better.
    Ryan
  3. #3
    Super Member
    Join Date
    Apr 2000
    Posts
    6,579
    central New York
    all makes and models
    Is the tiller running level? I'd thnk that the front gaurd should be catching them. On another note, with stones I only recommend the forward till!
  4. #4
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    4,579
    Windsor, CT.
    Kubotas: L3240GST B2320HST B5100D & G5200H
    Quote Originally Posted by art View Post
    Is the tiller running level? I'd thnk that the front gaurd should be catching them. <snip>
    My thought, exactly. If it is level, then maybe something like the guards from a rotary field mower would work - either chains or the rubber strip kind.
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  5. #5
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,927
    Northern Vermont
    Kubota, Case, Deere
    Could you mount some chain link fence or a piece of plywood to the 3pt arms? Did you try adjusting the feet to lower the tiller into the ground further?
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  6. #6
    Join Date
    Feb 2012
    Posts
    74
    Thank you all for your suggestions.
    One problem I had, I think, had to do with the level. It looked good before being lowered into the soil, but I noticed that once it was lowered, the front pitched up somewhat. So today I shortened up the top link to correct this. That helped some. Also, I have an ongoing issue (that I'm temporarily ignoring) with the drive shaft being about 2' too long, so the unit is riding a little farther back behind the tractor than it should. This I will deal with once it is removed, and the combination of those two factors, the leveling and having it a bit closer to the tractor, should help alleviate this situation, if not correct it. I may try adjusting the feet to get it down further, but I'll wait on that, as I'm very happy with the way it's operating in that regard.
    But I'm still thinking about building a guard or shield if it's necessary. It's a very heavy tiller, and there's plenty of potential for mounting something to the front of it, and still keeping it out of the way of the 3-pt. movement and shaft.
    I will be using it again in the next few days to test these adjustments, and will report. Thanks for your help.
    P.S. THE DRIVESHAFT IS NOT FULLY COMPRESSED. I HAVE AT LEAST 1" AVAILABLE (WHEN IT'S AT IT SHORTEST) BEFORE THAT HAPPENS. BUT UNTIL THE SHAFT IS SHORTENED, THE LOWER ARMS LONGER THAN WOULD BE BEST. AS THEY CONNOT RETRACT ANY FARTHER UNDER USE, THERE IS NO POTENTIAL FOR THE SHAFT TO BOTTOM OUT.
  7. #7
    Join Date
    Mar 2007
    Posts
    188
    B3030HSDCC, Oliver 77, JD LX288
    Quote Originally Posted by Lefty7 View Post
    I wouldn't be using it until that driveshaft is made to be the correct length. You don't want to break your tractor's PTO, do you?
  8. #8
    Join Date
    Feb 2012
    Posts
    74
    Quote Originally Posted by Earl Ohl View Post
    I understand your concern - and I knew when I mentioned this, the reader would not understand that the shaft is not compressed max. But to operate the unit without these concerns, I have the lower 3-pt. arms longer than I'd like - or would be optimum for best up/down travel. (Once the shaft it shortened, I will also shorten up lower arms.) There is no danger in breaking the PTO, only damage from the forward-kicking debris.
    Thanks again, Earl Ohl.
  9. #9
    Silver Member greenrider1's Avatar
    Join Date
    Nov 2011
    Posts
    125
    Dryden, NY
    Kubota L5740 HSTC
    I would get one of the heavy rubber horse mats from Tractor Supply, and make a flexible guard for the front. They have 3'x5'x1/2" thick mats for $22. They also have 4'x5'x1" thick mats. Cut with a sharp knife, or circular saw, drill holes, and bolt on. Should be heavy enough to knock down the big rocks, easy on the budget, and easy to fabricate.
    I just made a wide stone guard for the back of my truck (mounts on hitch for easy removal) for when I tow my boat using one of these mats.
    Kubota L5740, LA854 loader w/ QA bucket
  10. #10
    Platinum Member AStanton's Avatar
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    My local feed store sells heavy duty rubber mats for horse barns and such. They are about 1" thick and 3ft X 4 ft. Maybe you can buy one of these mats, cut it up and use it to deflect any wayward rocks. Just a thought.
Similar Threads
  1. Disc Harrow vs. Rotary Tiller
    By Neophyte in forum Attachments
    Last Post: 08-31-2006, 04:13 PM
  2. Tiller Landpride RTR0550 Reverse Rotation Tiller
    By rvtech in forum Attachments
    Last Post: 12-31-2005, 08:23 AM
  3. Land Pride reverse tine tiller & pull type aerator
    By Chase in forum Customization
    Last Post: 12-17-2005, 11:33 PM
  4. Tiller Another Tiller Thread
    By Arcane in forum Attachments
    Last Post: 11-23-2005, 09:30 AM
  5. Who else likes rocks?
    By karmakanic in forum Projects
    Last Post: 01-11-2003, 02:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
