Results 31 to 38 of 38
07-05-2012, 09:17 AM #31Platinum Member
- Join Date
- Aug 2010
- Posts
- 560
- Location
- De Soto, KS
- Tractor
- Kubota L5740-3/ Kubota ZD21 pro60
Re: Am I asking too much from my L5740-3?
If I am out with the square baler for 8 hrs, figure 2 hrs of road time total, 6 hrs baling. I average 100 bales an hr. By the end of the day I have used around 1/2 tank of fuel. So not too bad. I have brush hogged for 12 hrs straight before needing to re-fuel. 14.3 gal capacity. Hope this helps.
"It is better to be thought a fool, than to open your mouth and prove it."
07-05-2012, 09:19 AM #32Platinum Member
- Join Date
- Aug 2010
- Posts
- 560
- Location
- De Soto, KS
- Tractor
If I am out with the square baler for 8 hrs, figure 2 hrs of road time total, 6 hrs baling. I average 100 bales an hr. By the end of the day I have used around 1/2 tank of fuel. So not too bad. I have brush hogged for 12 hrs straight before needing to re-fuel. 14.3 gal capacity. Hope this helps. But we also use a JD 7410 and 6300. The 7410 mows and round bales and the 6300 rakes/tedds.
07-05-2012, 11:12 AM #33Elite Member
- Join Date
- Sep 2003
- Posts
- 3,945
- Location
- New Brunswick, Canada
- Tractor
- Kubota L5030 HSTC, MF 5455
I think mine holds 40 L so about 14 gal, if I'm running with the engine pegged continuously snowblowing etc, I can't get 5 hours from a tank. If I'm tedding or raking or baling, I get 10-15 hour + from a tank.
07-05-2012, 12:31 PM #34Platinum Member
- Join Date
- Feb 2009
- Posts
- 838
- Location
- Northeastern Minnesota
- Tractor
- 2011 Kubota L5740; 2005 Cat 301.8 MiniHEX; 2012 Kubota RTV 900
When you look up the engine curve from Kubota's engine site you will find the L5740 engine uses 3.7 gph at 100% power. The brake specific fuel consumption curve actually sweeps up pretty fast at the high end so as you back off the fuel economy gets better quickly. Pretty much matches what was said about fuel usage snow blowing vs. raking or tedding. I go through 2 tanks a day plowing or dissing and go days between filling gathering up bales.
L5740 w/FEL, 301.8 MiniHEX, RTV900, 13' tandem disk, 1 x 2 btm plow, 12' 3pt cultivator, bale spear, 7' rear blade, grading scraper, 6' KK tiller, pallet forks
07-09-2012, 04:35 AM #35
07-13-2012, 10:19 PM #36Elite Member
- Join Date
- Feb 2011
- Posts
- 3,822
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
I was thinking about this earlier and one thing that is bogging down is fluid in the tires if you have it. I have close to 55 gal. in my 4240.
07-13-2012, 11:26 PM #37Banned
- Join Date
- Dec 2011
- Posts
- 1,129
- Tractor
- L5450
Going up hills the fluid in the tires sure does bog the tractor down. Makes for a fun ride downhill too.
07-16-2012, 09:07 AM #38Platinum Member
- Join Date
- Aug 2010
- Posts
- 560
- Location
- De Soto, KS
- Tractor
You guys are right. I kinda forgot about that. Yeah I have 55 gal. in each tire as well @ 1298 lbs. Also, I don't keep my tires inflated very much for a better ride. Both of these will add rolling resistance robbing power on the road. Sooo, maybe I'm not asking too much, but expecting too much.
I was roading the JD6300 with just a 10 wheel rake the other day and it was dropping 2-3 mph on the hills. So maybe my little L is doin pretty good given what I'm asking it to do.
Similar Threads
L5740
By dieselbill in forum Kubota Owning/OperatingReplies: 8Last Post: 06-25-2011, 08:55 PM -
L5740 Autothrottle
By nebraskasparks in forum Kubota Owning/OperatingReplies: 0Last Post: 05-20-2011, 08:33 AM -
New L5740
By KnuckleDragger in forum Kubota Owning/OperatingReplies: 5Last Post: 05-13-2010, 04:11 PM -
New L5740
By JerryJHarrison in forum Kubota Buying/PricingReplies: 7Last Post: 10-09-2007, 09:20 PM -
L5740
By Kendall69 in forum Kubota Buying/PricingReplies: 8Last Post: 04-01-2007, 06:27 AM
