Broken Pin - BH77
   / Broken Pin - BH77 #1
Mac in PA
Somewhere North of the Mason Dixon Line
Kubota L 3800, Austin Western Pacer 100
Well it finally happened, the pin that holds the two cylinders on the boom broke Wednesday night.
I latched on to a rock in the ditch trying to pry it loose. I was working the bucket, boom and dipper at the same time, which had worked many times before to pry a rock loose. I heard a loud crack even over the roar of the engine at full throttle and ear protectors on. I then noticed that the boom cylinder and dipper cylinder were wiggling in two different directions at the anchor point. Checked it out and the pin had broken. Luckily there wasn't any weight in the bucket so it didn't damage the boom at the pin anchor holes.
The first picture shows the broken pin, which broke at the weak point, the grease groove. The second picture is the new pin. It may not be visible but it looked like the heat treating was different at the grease groove and 1/2 inch on either side of it. Improvement? ? ?:confused3:
Picture three is before the broken pin was removed. No evidence that it was broke. The last picture is with the new pin installed.
Before I assembled everything I pulled the cylinders back and made sure the new pin could be slid in place easily by hand. This verified that the pin anchors were not twisted or damaged.
I ordered the part Thursday from Messick's and asked them to get it UPS Next Day Air and I would pay the freight.
Warranty covered the cost of the part. Everything worked out as planned and I had the BH up and running the next day. :applause::applause::applause:
   / Broken Pin - BH77 #3
You could view it as a fuse failure...
At some point things are overstressed... it is good to have an affordable & easily replaceable part fail, before something major breaks.... KennyV
   / Broken Pin - BH77 #4
the pin was heattreated to hard thats why it snaped.
   / Broken Pin - BH77 #5
The only problem with that is that most of these I've seen bend the cylinders ears and the tabs on the boom with it.
Was this one of the early 'problem' pins or one after the recall? I've been thinking about a BH77 for my B3200 but this issue has worried me all along.
   / Broken Pin - BH77
Was that a 3/4" or 1" diameter pin?
The pin is 1.172" in diameter or a little over 1 1/8"
I bought the BH77 new January of this year. I was not notified of a recall if there was one for my unit.
I believe I was very lucky that I caught it before any major damage was done. I'm not sure what caused it to break but it looked like the pin was partially broken or cracked. There was a dark area on the one side of the break about 1/8" wide, which indicated to me that it was cracked for a while before breaking.
Mac
   / Broken Pin - BH77 #8
Mine broke the second time I used my BH. I was digging a pine stump out of sandy soil and SNAP. It mangled the ears on the dipper and the dealer replaced everything under warranty.
   / Broken Pin - BH77 #9
IMHO: The shared mounting point allowing the cylinders to apply force against each other is probably the problem. If this is a common problem on the backhoe the only relatively inexpensive "fix" would be to retro for a larger diameter pin.
   / Broken Pin - BH77
Replacing the pin with one that has no grease groove will probably fix the problem also. I don't believe that this groove is necessary.
Mac
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2008 Ford E-350 Versalift Vantel29N 29FT Bucket Van (A50323)
2008 Ford E-350...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
