Spikes
The 'Bota sprung a slow dripping leak in a remote tap block under the seat today. I was brush hogging and noticed it when I stopped for a break.
This is probably easy for you regulars, but I traced the leak to near the threads of the fitting and tightening the fitting didn't do any good. Almost looks like a crack in the cast block from the blurry picture.
Can I use PTFE or something to seal the threads? At least that will tell me if it's a crack. I would rather remove the block (just 2 bolts) but I'm afraid I will cause more leaks. Besides, there is a small tube coming from the bottom of the block and I can't tell where it goes.
Anyone know where I can get a block-off plate to remove the hoses completely? They don't do anything, they are connected together and just hang over the lift arms in the back. Probably used to connect to some attachment the PO had.
So, PTFE tape or find a stock block off plate?
Thanks!
By the way, it's not coming from the hose or crimp, definitely from the threads or a crack in the threaded portion or cast part.
Thanks!
