Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,656
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Default Re: L4240 upgrades
    Quote Originally Posted by 94BULLITT View Post
    The instructions said to move the manual link to the left side. you can get more adjustment with it but I have not had to use it.
    Same here, mine came from the dealership that way.
  2. #12
    Veteran Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    2,383
    Bay Roberts, Newfoundland, Canada
    Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
    Well your off to a great start. Watch out though. Customizing can be addictive
    ...Excellence is not just a skill. It is also an attitude...
    Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
    YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25DTLB With Wallenstein BXM32
    Kubota ZTR ZG 222 Z
  3. #13
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,808
    NOT HERE
    Quote Originally Posted by 4shorts View Post
    Thanks, I have more that I want to do I just can't find the time plus I want to make 3 implements.
  4. #14
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,808
    NOT HERE
    Quote Originally Posted by TripleR View Post
    I need to do something about those stupid hoses on the tnt, they could have supplied some better stuff. I think I need a few 45's for them o fit better.
  5. #15
    Platinum Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    986
    Indianapolis
    Kubota L3940 Ford 8N Ford 6000
    I don't have the tilt, but I did install my own top. I used -4 hoses for better installation. The smaller inside diameter works well speed wise (I don't think anyone needs a speedy tnt), and just lays out better. Philip.
    Attached Thumbnails Attached Thumbnails L4240 upgrades-toplink10.jpg   L4240 upgrades-toplink07.jpg
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/quick attach
    HD 72" round back bucket
    turf tires
    Ford 8N 1950
    Ford 6000 diesel 1961
    JD LX188 1997
    JD L110 2003
    Woods RD7200 finish mower, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 3 point 2" drawbar receiver, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
  6. #16
    Join Date
    Mar 2009
    Posts
    13,656
    Missouri
    Quote Originally Posted by PHILIP8N View Post
    Looks good, I have no idea what size my hoses are, but agree that speed is of no importance to me on mine. I could get by fine without the side link, but not the hydraulic top link.
  7. #17
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,808
    NOT HERE
    I don't know what size my hoses are. I have a few ideas on rearranging them, you can't go by what the instructions said.
    When I had the Bobcat I only had a hydraulic toplink, and it seemed like I mostly need a sidelink. I don't use the sidelink on the 4240 as much on the toplink but it is still useful.
  8. #18
    Join Date
    Mar 2009
    Posts
    13,656
    Missouri
    Will be interested in what you come up with on arranging your hoses. My son rerouted ours the other day, but I haven't even looked at it even though I've used it twice since then.
    Oh I like the hydraulic sidelink and it's great with the box blade, but we use rotary cutters more than anything else and when my sidelink was in the shop, I ran with a regular side link for quite a while and it wasn't a big deal.
    I have a small job coming up where it will be great. I will be moving rock dumped too close to our shop which created a slope, so while the tractor will be tilted, the box scraper won't.
  9. #19
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,888
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Quote Originally Posted by crazyal View Post
    That'll work. Is there any reason why you have the manually adjustable link for the tilt and the hydraulic cylinder?
    It is often very difficult if not next to impossible to make the hydraulic side link exactly the size of the stationary link and still have an equal amount of tilt to each side. By installing the manually adjustable side link opposite of the hydraulic link, you then set the hydraulic link at mid stroke and then level the hitch out with the OEM adjustable link. Now you have an equal amount of tilt to each side. This only works if the design of the hydraulic link is to obtain an equal amount of tilt to each side. There are side links out there that are intended to only tilt in one direction : and if you were to adjust the OEM link to get the tilt equal with one of those hydraulic side links, then your implement would never lift up as high as it should.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  10. #20
    Elite Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    4,709
    Northern Vermont
    Quote Originally Posted by MtnViewRanch View Post
    Sounds logical. I was curious because the non adjustable link has three pin holes while the adjustable one only has two.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
Similar Threads
  1. Windows 7, Upgrades
    By ren1pa in forum Private Party Ads
    Last Post: 07-20-2011, 10:03 AM
  2. hydraulic upgrades
    By eyedoc in forum Customization
    Last Post: 06-09-2008, 11:47 PM
  3. Armrest and other upgrades
    By IrTxRx in forum Power Trac
    Last Post: 11-10-2007, 10:10 AM
  4. 1602 Upgrades
    By FLinTexas in forum Yanmar
    Last Post: 09-08-2005, 05:32 PM
  5. Upgrades
    By Ibrahim in forum News/Feedback
    Last Post: 11-11-2003, 06:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
