Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    New Member kb9okb's Avatar
    Join Date
    Sep 2012
    Posts
    13
    Evansville, IN
    Kubota BX25
    Default BX25 MMM 'Up Position'
    So I just bought a used BX25 and love it so far. However, I am having problems getting the mid-mount-mower to lock in the upmost position... no matter what I do it raises and lowers when I raise and lower the 3 point hitch... I have tried the 'cutting height adjustment' on both extremes. I have it adjusted as far as it will go (on 4) next to 'TOP' - but not exactly on 'TOP' - is there something special I need to do to get it to lock 'up?' I've tried pushing in on the button, pulling up, etc.
    The adjustment does let it 'stop going down' at a higher position when on 4 vs. when it's set on 1 and goes all the way down, but it's still too low and drags when I'm operating a box blade, etc.
    Please help... thanks!
  2. #2
    Platinum Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    987
    Rochester, MN
    Kubota BX2230
    Default Re: BX25 MMM 'Up Position'
    Welcome kb9okb! You've come to the best tractor resource on the planet.
    OK, I don't know how BX25's differ from BX2230's, but here's a thread I started about my mower height control.
    http://www.tractorbynet.com/forums/k...t-control.html
    In my case, the whole bracket was broken off the frame. So, when you twist the control, does it feel firm or does it wiggle all over the place? It should be firm. Does your mower stay up at at setting at all? If it does, then the height control is at least in place. Good luck!
  3. #3
    Join Date
    Sep 2012
    Posts
    13
    Evansville, IN
    Kubota BX25
    Yes, the adjustment is solid and it does affect the height at which the mower stops descending. But it does not lock it in the up position, it merely changes it from sitting all the way on the ground to about half-way up, but far from the TOP position, i.e. the position it's in when the 3 pt hitch is elevated completely.
  4. #4
    Gold Member uglyboywith11fingers's Avatar
    Join Date
    Sep 2011
    Posts
    292
    Georgetown, Ontario
    2007 BX24TLB, 1998 TG1860G
    On my BX24, which I think is the same as a BX25 in this regard, I raise the mower deck using the hydraulic control lever, then rotate the cutting height control knob to the 'TOP' position.
    My mower deck does not go down when using my 3 pt hitch.
    Your issue is perhaps that you can't move your knob to the TOP position...
    Time to slide underneath to see why... maybe some lubrication required ?
    I also raise my guage wheels to the highest position for maximum ground clearance.
    Pete
  5. #5
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,836
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    When you raise your deck are the bump stops contacting the frame or is there a big gap?
  6. #6
    Join Date
    Sep 2012
    Posts
    13
    Evansville, IN
    Kubota BX25
    Okay that's good to know. Does the knob 'snap' into the top position? Also, is the top label exactly aligned with the arrow? You may be right... mine only seems to go to '4'
  7. #7
    Join Date
    Sep 2012
    Posts
    13
    Evansville, IN
    Kubota BX25
    Where are the bump stops / how can I tell?
  8. #8
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,836
    I know there is one on the right front of the deck, it looks like a piece of angle kinda, and I think a bolt contacts the left side but I am going from memory.
  9. #9
    Member HeLa's Avatar
    Join Date
    May 2007
    Posts
    41
    Hunterdon County, NJ
    Kubota BX25 TLB
    Did you buy the machine new? If so, and the dealer installed the deck, then it *should* be properly adjusted. I found that mine needed a little fine tuning.
    If it hasn't been done, or you're not sure, it can't hurt to break out the manual and your deck gauge to make sure everything's right. If the deck isn't going up high enough, the height adjustment wheel will block and you won't be able to set the TOP setting.
    There are a few settings on the deck that need to be checked to ensure that it's level, but this one would be my guess for your current issue.
  10. #10
    Platinum Member GolfAddict's Avatar
    Join Date
    Oct 2011
    Posts
    558
    SE Minnesota
    Kubota BX24; John Deere 4020
    Quote Originally Posted by kb9okb View Post
    Okay that's good to know. Does the knob 'snap' into the top position? Also, is the top label exactly aligned with the arrow? You name be right... mine only seems to go to '4'
    Yes, it should "snap" or click into that position just like when moving it to the other height settings, and it will then be lined up with the arrow. It sounds like you are not able to rotate it into the Top position. I have the problem on occasion - sometimes it will rotate right in, other times I have to fiddle a bit. I'll drop the deck down, lift it back up, wiggle the knob a bit... (btw, make sure to lift long enough that the 3pt lift arms are all the way up)
    If it's giving me a bit of hassle, I've found that if I rotate it around the other way it will then go into Top. That is, go all the way down to zero then on to the Top position rather than going "up" past 4 into Top.
    I know it's time for me to get out the manual and make some minor adjustment, but since I can always manage to get it into Top with just a few seconds of fiddling I haven't bothered to yet...
Similar Threads
  1. 3-Point Hitch MMM Top position
    By Jeff F. in forum Kubota Owning/Operating
    Last Post: 07-17-2010, 12:07 PM
  2. HELP!!, Keeping the MMM in the UP position.
    By don716 in forum Kubota Owning/Operating
    Last Post: 04-20-2007, 06:49 AM
  3. Running BX MMM in TOP position OK?
    By Henro in forum Kubota Owning/Operating
    Last Post: 05-05-2006, 06:32 PM
  4. Running BX MMM in TOP position OK?
    By Henro in forum Kubota Buying/Pricing
    Last Post: 05-03-2006, 10:55 PM
  5. position control and MMM adjustment
    By medfieldtractor in forum Kubota Owning/Operating
    Last Post: 10-31-2003, 03:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
