Results 1 to 10 of 10
  1. #1
    Join Date
    Apr 2008
    Posts
    74
    Default 2011 Kubota L3200 HST Filters Help
    I have found all the filters(wix brand) except the trans. filter and the Hydrostat filter. Does anyone have a non kubota part number such as wix, napa, or purolator for this application. I dont get caught up in all the genuine high dollar kubota parts gimmicks. I am sure kubota does not make filters. Any help would be appreciated. Thanks
  2. #2
    Join Date
    Apr 2008
    Posts
    74
    Default Re: 2011 Kubota L3200 HST Filters Help
    Just got raped by kubota. Couldn't wait any longer so went down to local Kubota for the filters. $77 bucks for those 2 filters, and they didn't even use any vaseline. That is rape. As soon as I find out the wix or napa numbers I will post them.
  3. #3
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I recommend sticking with kubota filter while you are under warranty so if you have a issue they can't say you weren't using our filter. If you give me the kubota part number I can try crossing it over at Napa. I tried looking it up by application but they did not even list it by application. How much were the filters?
  4. #4
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,782
    Branson, Mo.
    Kioti DK35se Hydrostat
    Good luck finding them.. I think one can be found , but seems to me the other one I think the hydro filter cannot be found. All of these type of filters on all brands are very expensive.. I think I gave $80 for the hydro filter alone on my Kioti. If you do find good replacements be sure to post up the links where they can be found, I am sure a lot of the guys would appreciate it.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  5. #5
    Super Member
    Join Date
    Dec 2007
    Posts
    9,892
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Great thread here. I use kubota filters because I perceive them to be a greater value but the OP is right and I'm sure Kubota makes nothing and subs it out. I'd also bet there is a lot of cross-over as well and in fact my JD 790 has the same air filters as my Kubota L4300.
    Years back I used to have the big Wix and Fram Industrial filter cross reference books and most everything from back then crossed over to one or the other. Wix makes a great filter and it will be interesting to see any price differential. As I recall, I stayed with dealer filters because there wasn't much of a price difference when there was an alternative competitor, The only time Kubota seemed outrageous was when they were the only filter out there and there was no cross-over to go to.
    May I be the kind of person my dogs think I am,
  6. #6
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    The filters for the Bobcat were reasonable. The oil filter was the only one wix had and it was the about the same price as a Bobcat. I saw a exploded view of a Bobcat filter and it looked like a wix.
  7. #7
    Join Date
    Apr 2008
    Posts
    74
    HH3A0-82623 $47.26 HHK70-14070 23.75 Plus Tax =76.87 That hurt the old pocketbook!
  8. #8
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by loudhornsrule View Post
    I tried them at NAPA and Carquest with no luck I then went to wix and I found all the filters like you had by application. I tried the kubota number HHK70-14070 on their interchange and found a filter. I could not find one for the HH3A0-82623. Check and be sure these filters will work before you use them. Added the rest of the filters for a reference for anyone else.
    Kubota # Wix# Napa#
    HHK70-14070, 51367, 1367 (should be around $15)
    air, 42985, 2985
    air, 46438, 6438
    fuel, 33830, 3830
    engine, 51307, 1307
    Sorry my chart did not turn out good after I hit submit.
    Wix Filters - Product Catalog search results
    If you can find the filters in any brand post the number and I will try to cross it at napa or carquest. They both sell Wix filters. I tried finding the last filter in a Wix, purolator, fram, hastings, and donaldson. You can do a filter request at wix. http://www.wixfilters.com/Lookup/PartResearch.aspx
  9. #9
    Join Date
    Apr 2008
    Posts
    74
    Roger, thanks. The filter HH3A0=82623 FOR $47 BUCKS has a removable magnet in the top.
  10. #10
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    You're welcome. I looked everywhere I could think of for that filter, I also checked mile guard. I think you may have to do a filter request and see what wix can do.
Similar Threads
  1. Price Check L3200 HST 4WD R4
    By ZAR2USA in forum Buying/Pricing/Comparisons
    Last Post: 10-01-2012, 10:51 AM
  2. Kubota L3200 HST or John Deere 3032E
    By RRX in forum Buying/Pricing/Comparisons
    Last Post: 09-29-2012, 09:32 PM
  3. Buying Advice 2012 L3200 HST
    By BoonDoc in forum Kubota Buying/Pricing
    Last Post: 09-11-2012, 07:16 AM
  4. plowing with a L3200 hst
    By skind in forum Kubota Owning/Operating
    Last Post: 05-24-2012, 02:35 PM
  5. Comparison 2011 KUBOTA L3800&2011 KIOTI DK35SE
    By RCABOWHUNTER in forum Kubota Buying/Pricing
    Last Post: 04-04-2011, 09:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
