Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Gold Member snpower's Avatar
    Join Date
    Nov 2010
    Posts
    308
    Charlottesville, Virginia
    Kubota BX2360
    Default Problem reconnecting BX2360 to loader
    Ok. Bucket not quite level last time I dropped the loader. I got the ride side piston full extended and the left side not nearly so much. I can't disconnect the blue line due to pressure; how can I get both pistons back in sync? Pictures probably explain better.
    Problem reconnecting BX2360 to loader-image-908439590-jpg
    Problem reconnecting BX2360 to loader-image-2609836552-jpg
    2010 BX2360
    54" MMM, 5' TW rear blade
    5' TW rake
    4' Frontier Box Blade
    Male Red Fox Labrador Retriever
    1963 McIntosh Tube Amp w/1959 Citation I Preamp
    Bozak B302A Speakers
  2. #2
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,821
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Problem reconnecting BX2360 to loader
    If you have a hi lift jack or way to attach a hoist, I would hook the hydraulics up, raise the FEL above your mounting points then use the joy stick to realign the arms, lower it then go from there.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  3. #3
    Join Date
    Nov 2010
    Posts
    308
    Kubota BX2360
    Default
    Nevermind!!
    2010 BX2360
    5' TW rake
  4. #4
    Veteran Member GolfAddict's Avatar
    Join Date
    Oct 2011
    Posts
    2,353
    SE Minnesota
    Kubota BX24; John Deere 4020
    I've had the same thing happen. Leaving the hoses hooked up, you should be able to use the joystick to close the cylinders. As they close, the one will fully close first then the other will catch up till both closed. Looks like you may have to lift that one side a bit to clear...
  5. #5
    Join Date
    Oct 2011
    Posts
    2,353
    SE Minnesota
    Quote Originally Posted by snpower View Post
    Nevermind!!
    Guess you can ignore my post.
  6. #6
    Join Date
    Mar 2009
    Posts
    18,821
    Missouri
    Quote Originally Posted by GolfAddict View Post
    Mine too.
  7. #7
    Join Date
    Nov 2010
    Posts
    308
    Kubota BX2360
    Default
    Oh no I appreciate the advice. I let the pressure bleed off, disconnected the blue line, lifted the loader with one arm whilst pushing one piston in, then lowered the loader back into the brackets on the tractor.
    2010 BX2360
    5' TW rake
  8. #8
    Join Date
    Mar 2009
    Posts
    18,821
    Missouri
    Ours on our old BX2200 bled down and was a bear, so my sons would just lift and move it around like you, now at my age, I have to use jacks, hoists or loaders on other tractors.
  9. #9
    Gold Member
    Join Date
    Jun 2008
    Posts
    260
    SW Iowa
    BX24
    For future reference there is an easier way, mentioned in part by Golfaddict. Without disconnecting anything manipulate the controls to collapse both cylinders. Then have the loader positioned so when you extend the cylinders they bump up against the brackets. I do it all the time as I collapse the cylinders when it is not on my tractor.
    Take Care,
    Doug in SW IA
  10. #10
    Approved Advertiser
    BXpanded's Avatar
    Join Date
    Jul 2008
    Posts
    717
    Knoxville, TN
    Also for future reference: When the mounts are in the position you pictured with one over and on the back side of the mount, curl the bucket. The arms should lift enough to clear the mounts. You can usually just push the extended mounting arm inward by hand to even it with the other arm. The cylinders have a cross over so it's pretty easy. Or you can use the hydraulics as described above.
    Once you have that all squared away, lift the low side of the bucket and kick a block under it to level it with the tractor. Re-install the loader as normal.
    Another hint: When removing the loader on an un-level surface, lower the bucket till one side touches the ground. Put a block under the other side to take up the space and all should be even when re-installing.
Similar Threads
  1. BX2360 transmission problem
    By CodeSlinger in forum Kubota Owning/Operating
    Last Post: 09-07-2015, 07:11 PM
  2. MF1533 - Reconnecting FEL
    By Liren in forum Massey Ferguson Owning/Operating
    Last Post: 06-12-2010, 10:11 AM
  3. Very tough to get loader off of bx2360 please help
    By newdeal in forum Kubota Owning/Operating
    Last Post: 04-19-2010, 10:30 PM
  4. deck problem on 54" fine cut, on my new bx2360
    By shrekbelly in forum Kubota Owning/Operating
    Last Post: 05-27-2009, 05:18 PM
  5. gc2310 reconnecting BH
    By tccontender in forum Massey Ferguson Owning/Operating
    Last Post: 04-27-2007, 01:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
