Results 1 to 10 of 12
11-05-2012, 04:47 PM #1
Anyone ever try the LED light bars?
Curious if anyone has tried one, I was thinking about mounting a 10" under my ROPS bar.I wouldlike one that swivels 180 degrees so I could use it with my BX23 BH. I have noticed the prices are coming down on them. I thought the flood light would be a good upgrade,but have not seen any mounted on a tractor and wondered about the output. I upgraded to an alternator on my BX, so amperage draw really in not a concern, but was curious about the LED output as I am more of a halogen guy.
Its been three years since I did the alternator and still cannot make up my mind on nice floods for my BX..I was looking at the Hella's retangular 500's, figured the would give more headroom and fill the corner of the ROPS.
But now I am wondering about a large flat LED in the middle.Kubota BX-23, BH, FEL, MMM, Various Bro-tek attachments, Exmark Lazermark.
ASME Certified welding inspector specializing in Visual, Mag Particle, Dye Penetrant, and Ultrasonics
11-05-2012, 04:55 PM #2Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,376
- Location
- Bay Roberts, Newfoundland, Canada
- Tractor
- Custom 2011 Kubota 5740 HSTC-3, Grand Cab. Yep. Life is grand! 2013 Kubota BX25D.
Re: Anyone ever try the LED light bars?
Yep I have
the video will show the extent of them.
Kubota 5740 upgrades - YouTube...Excellence is not just a skill. It is also an attitude...
Photo's of my restoration work and tooling: http://www.flickr.com/photos/15602393@N05/
YouTube Video's: http://www.youtube.com/results?searc...rch_type=&aq=f
2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
2013 Kubota BX25DTLB With Wallenstein BXM32
Kubota ZTR ZG 222 Z
11-05-2012, 08:42 PM #3Silver Member
- Join Date
- Jun 2006
- Posts
- 192
- Location
- South Central PA
- Tractor
- Kubota BX2350
Wow!! Nice mods!
Originally Posted by 4shorts
BX2350 - FEL, 48" Box blade, Markham toothbar, ROPS mounted lights, BXpanded bucket hooks, 48" Howse brush cutter
11-05-2012, 10:57 PM #4Veteran Member
- Join Date
- Jul 2008
- Posts
- 2,376
- Location
- Tractor
Kubota ZTR ZG 222 Z
11-06-2012, 09:45 AM #5
Though probably not optimal for ROPS, I just bought one of these from ebay for the roof of my skid steer for snow removal or if I head down the street to refuel.
Probably something similar to what 4shorts installed will be more to your application. Something like this. There are many others out there, this was just an example.
If you order from ebay, keep a close eye on where the item is coming from. Many are directly from China, so who knows how long it may take to receive the item. And what if there's a return issue?
Even some of the lights shown as coming from Walnut, California are from the same outfits. Do a little research and be sure where you're buying from if you choose the ebay route.Todd
_____________________________________________
"The trouble with quotes on the Internet is that it's difficult to discern whether or not they are genuine." --Abraham Lincoln
2008 Bobcat S185 Skid Steer with enclosure, heat & A/C • Erskine model 2010 73" blower •TSC Boom Pole adapted to QA • Bradco 48" pallet forks • JLG T350 Boom Lift • 1997 Ford F Super Duty 7.3 Powerstroke w/ Altec AT 200A aerial lift • CAM Superline 6x12 dump trailer
11-06-2012, 02:42 PM #6
Do ya'll think a good quality set of fog lamps would be sufficient to work with safely? I am more interested in a wide angle beam, rather than a distant spot beam. I was looking at these and wondered how they would work?
My Hella Lights :: HELLA 550 Fog
LED spot bars are still too high I'm afraid, and I always get burned on the Lumens.Kubota BX-23, BH, FEL, MMM, Various Bro-tek attachments, Exmark Lazermark.
11-06-2012, 04:47 PM #7
I guess I missed what exactly you were looking for. You want lights that you can see to do stuff with. Not lights that allow you to be seen by others.
My only experience with that type of light was buying a Kubota factory rear work light kit. Included the switch and simply plugged into the factory pigtails in my cab's headliner.Todd
11-09-2012, 01:21 AM #8New Member
- Join Date
- Nov 2012
- Posts
- 1
- Location
- Tulalip, WA
- Tractor
- Kubota B20
This tractor is like a rolling, flashing work of art!
11-09-2012, 01:49 AM #9Veteran Member
- Join Date
- Jan 2008
- Posts
- 1,469
I've gone LED everything. LED street lights, LED area lights, LED security lights. I just switched our some 1000W sodium lights on the building with 50 watt LED and the LED throws the same light, at 1/20th the cost. I can run the LED all month darn near for what the 1000 watt cost me in a day.
Think about it on a 20 amp circuit you can run nearly 40 led lights rather than 4 of the 500 watt halogen. Bets part is they don't get HOT. Those work light are fire hazards.
I connected a LED street light to the top of a tractor ( you all know how bright street lights are ) and it throws light 360 degrees
11-09-2012, 06:37 AM #10
Similar Threads
Will this LED light work on my Ford 9N or 8N? Whelen PAR-46 Super LED
By macecase in forum Parts/RepairsReplies: 2Last Post: 10-10-2012, 03:54 PM -
Another LED or Halogen light question
By gabrichter in forum Kubota Owning/OperatingReplies: 25Last Post: 01-28-2012, 09:38 PM -
LED work light
By InThePines in forum Kubota Owning/OperatingReplies: 22Last Post: 11-15-2011, 09:53 PM -
rear led work light on 2520
By lowechj in forum John Deere Owning/OperatingReplies: 5Last Post: 10-31-2011, 10:55 PM -
LED Work light
By kuboman in forum Kubota Owning/OperatingReplies: 39Last Post: 02-12-2010, 12:41 AM
