Results 1 to 1 of 1
  1. #1
    Veteran Member npalen's Avatar
    Join Date
    Nov 2009
    Posts
    1,259
    Beloit, KS
    Kubota B9200 HSTD and New Holland TC29DA
    Default Replacing Front Wheel Bearings on a FWA
    Replacing Front Wheel Bearings on a FWA-100_3299-jpgReplacing Front Wheel Bearings on a FWA-100_3300-jpg
    Had a very slow 90W leak out of the right front spindle on my B9200 so ordered replacement seals from Messick's and also a block heater while I was at it. (Messick's=great folks to work with)
    Noticed a lot of play in the hub after removing the wheel/tire and discovered the outer bearing had shot craps. The cage had broken letting the balls lose their spacing. Put in a new 6305 bearing and the new seal and seems good to go. Sure glad I decided to replace the seal even though it wasn't leaking badly otherwise I may have run a long time on the bad bearing and caused some expensive damage. I'm impressed with the workmanship in this kubota assembly
Similar Threads
  1. Yanmar Front Wheel Bearings
    By NCDaveD in forum Parts/Repairs
    Last Post: 07-26-2012, 04:16 PM
  2. JD 790 front wheel bearings
    By dking1000 in forum John Deere Owning/Operating
    Last Post: 09-14-2010, 11:54 PM
  3. Replacing steering wheel bearings on 855
    By kimodc in forum John Deere Owning/Operating
    Last Post: 01-30-2010, 09:52 PM
  4. Front Wheel Bearings - TS1610
    By dasfaust in forum Iseki
    Last Post: 06-29-2009, 06:12 PM
  5. Greasing Front Wheel Bearings
    By Pooh_Bear in forum ATVs & Utility Vehicles
    Last Post: 05-07-2008, 12:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
