Page 10 of 12 FirstFirst ... 789101112 LastLast
Results 91 to 100 of 120
  1. #91
    New Member
    Join Date
    Oct 2012
    Posts
    19
    Bark River Michigan
    1947 Farmall M
    Default Re: Does your tractor stay in or outside?
    I don't use my tractor much yet. I don't have a clamp on my muffler so when I'm done useing it, I let it cool and take the muffler off. That way I can cover the whole tractor fast and easy.
  2. #92
    Bronze Member Onederdog's Avatar
    Join Date
    Mar 2006
    Posts
    68
    Kuna, Idaho
    Kubota L45
    Mine shares a three sided lean-to with the wife's truck and some dog agility equipment. A nice home after spending two years outside on the dealers lot.
    Kubota L45 TLB
    Land Pride Box Scraper, Rear Blade,
    Land Pride Dual Spindle Mower
    King Kutter 72" tiller
  3. #93
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    I have two shelters where my tractor and equipment are stored. All my equipment is enclosed by fence in a section of my yard. Our two outside dogs roam freely in this area. I use diesel supplement year round. I don't have a block heater.
    The PUPIL who does not surpass his Master, fails his Master.
  4. #94
    Join Date
    Jan 2012
    Posts
    1,418
    Ma
    Kubota b2920
    Quote Originally Posted by Onederdog View Post
    How do you keep the fel up so it doesn't sink over time and hit the car?
  5. #95
    Join Date
    Mar 2006
    Posts
    68
    Kuna, Idaho
    Kubota L45
    Well is has a loader lock lever, however it's not working at the moment and suppose to be fixed under warranty. So for now I just have to raise it up every 3 or 4 days.
    Kubota L45 TLB
  6. #96
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,071
    north idaho
    Kioti DK45SE hst cab
    them make, or you can make, a simple sleeve that slips on the front FEL cylinder. it prevents the loader from coming down.
    i used to stockpile tons of dog agility stuff before the wife got to lazy to compete...hehe. actually the dogs got too old to compete.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  7. #97
    Join Date
    Dec 2010
    Posts
    185
    Love, VA
    Kubota B7100 HST 4WD
    Inside.
    "For I am not ashamed of the gospel of Christ..." Romans 1:16
    94 Dodge Ram 2500 CTD
  8. #98
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,718
    Branson, Mo.
    Kioti DK35se Hydrostat
    Hate to tell you this, but the loader lock lever, will not prevent the loader from leaking down, Its purpose is to prevent someone from moving the control valve lever. It has nothing to do with the leak-down from the valve or cylinder seals. Also if a hose were to break, it will come down instantly with great force, and your car hood will be history. It is your loader, and your car.. just saying
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  9. #99
    Join Date
    Jan 2012
    Posts
    1,418
    Ma
    Kubota b2920
    Quote Originally Posted by k0ua View Post
    James K0UA
    That's what I was thinking unless it'd different than the lock lever on mine. I like the idea though, saves a ton of space if there's a way to keep it up there... maybe I'll try it with mine and a length of chain to a rafter to hook on the bucket lifting hooks...
  10. #100
    Join Date
    Mar 2006
    Posts
    68
    Kuna, Idaho
    Kubota L45
    Seems like my old Mahindra and my JCB backhoe both came with a piece of steel that was designed as a mechanical safety device to prevent the loader from falling while working on the equipment. Seems kind of strange that the "Great" kubota doesn't include such a thing.
    Kubota L45 TLB
Similar Threads
  1. Replies: 67
    Last Post: 04-02-2014, 08:07 PM
  2. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 09:29 PM
  3. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 10:00 AM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 03:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-08-2007, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
