Page 11 of 12 FirstFirst ... 89101112 LastLast
Results 101 to 110 of 120
  1. #101
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,177
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Does your tractor stay in or outside?
    Quote Originally Posted by Onederdog View Post
    Seems like my old Mahindra and my JCB backhoe both came with a piece of steel that was designed as a mechanical safety device to prevent the loader from falling while working on the equipment. Seems kind of strange that the "Great" kubota doesn't include such a thing.
    I think you could make one pretty easy with a piece of C channel.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #102
    Veteran Member rbarker's Avatar
    Join Date
    Jul 2003
    Posts
    1,154
    Massachusetts
    BX 25
    Default
    Quote Originally Posted by k0ua View Post
    Hate to tell you this, but the loader lock lever, will not prevent the loader from leaking down, Its purpose is to prevent someone from moving the control valve lever. It has nothing to do with the leak-down from the valve or cylinder seals. Also if a hose were to break, it will come down instantly with great force, and your car hood will be history. It is your loader, and your car.. just saying
    James K0UA
    Actually I think he said it is his WIFE'S car! Now there's a conversation I'd rather not have... LOL!
    Sent from my iPad using TractorByNet
    Bob B.
    Kubota BX25, FEL, 60" MMM, Curtis cab with heat
    Kubota BX2750D snow blower, 5' Estate rake, 5' rear blade
  3. #103
    New Member
    Join Date
    Oct 2011
    Posts
    5
    Binbrook Ont. Canada
    Kubota BX23
    I keep my BX23 inside my pole barn with my rv stuff. Pulled the battery, keep it on a trickle charger as I dont use it through the winter months. Got a walk along snow blower to keep both the drive ways clear.
  4. #104
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,960
    Hudson, Maine
    2003 NH TC30
    I am using a tarp building this year- shelterlogic over gravel/tarp/plywood for floor. Stays dry. Tractor is plugged in. I used to cover just the seat and steering wheel against the rain and snow. I debated building with wood- but this was quick- going up on the weekends- 1 person operation.
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  5. #105
    Member
    Join Date
    Nov 2012
    Posts
    26
    St. Helens, Oregon
    L4300
    Kicked out the son-in-laws CJ7 out of the garage and tarped it and installed my l3400.
  6. #106
    Join Date
    Sep 2009
    Posts
    76
    Both of my B's are in a cement floored, tight and dry barn. Some of the attachments live in 3 sided, gravel floored run-in sheds. This stuff is just too pricey to subject to the elements on a full time basis.
    _______________________________________________
    7610 HST
    352 FEL w/toothbar
    R4's w/chains
    5' Kubota power-angle plow
    5' Rhino grader blade
    4' Landpride HD box blade
    6' York rake
    5X8 stake-side trailer.
    B6100 HST
    turfs w/4' MMM +3pt trailer hitch.
    American 25HH splitter
  7. #107
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,758
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154S
    I live out in the woods in Michigan, populated by huge populations of gnawing critters that scurry around year round looking for food and some place to build a nest [ with close access to lots of wire and stuff to chew on and taste ]. So, I keep anything that I don't want ruined in my 40 by 80 pole barn... which I strive to keep a 'critter free zone'.... I was also brought up to keep stuff in 'ready to go' shape, and barn storage helps me rest more worry free at night... not bothered by long dead ancestors trying to lecture me as I try to sleep... [ the family curse.. ]
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  8. #108
    Silver Member bx2670's Avatar
    Join Date
    Nov 2011
    Posts
    121
    Pilot Mountain N.c.
    2013 Bx 2670
    This is my Bx2360's new home (14x32) along with its attatchments. I got some Harbor Freight furniture dollies 1000lbs rating and mounted them to 3/4 plywood sheets for FEL and BB to be able to roll around to store and attatch easier.On the plugger I was able to mount casters to the bottom of the three stands
    Does your tractor stay in or outside?-img_2539-jpgDoes your tractor stay in or outside?-img_2541-jpgDoes your tractor stay in or outside?-img_2542-jpgDoes your tractor stay in or outside?-img_2543-jpgDoes your tractor stay in or outside?-img_2544-jpgDoes your tractor stay in or outside?-img_2546-jpg
  9. #109
    Join Date
    Jul 2003
    Posts
    1,154
    Massachusetts
    BX 25
    Default
    Quote Originally Posted by bx2360 View Post
    Being in the market for a new shed myself (not as big) did you build it yourself or was it a prefab? Do you have a door in the end to drive in and would it accommodate the taller Rops of the BX25 (84.3")? Did you do anything special with the floor to handle the weight of the tractor? What did you do for site prep?
    It looks real nice and plenty roomy for all your gear.
    Bob B.
  10. #110
    Join Date
    Nov 2011
    Posts
    121
    Pilot Mountain N.c.
    2013 Bx 2670
    It was prefab did'nt get door on end, had to get folding Rops for a Bx25 did'nt realize when I ordered it a Amish style roof is a little shorter than a A frame roof but I do have more loft space. Floor is built like a house with 16" floor joist 5/8 plywood on those and 5 4x4 post running the whole length of it to rest on blocks.Just cleared out some pine trees and cut stumps down to ground level.If you can go bigger than you plan you can always use the extra space I was gonna get a 14x28 and glad I went 32!!!!
Similar Threads
  1. Replies: 67
    Last Post: 04-02-2014, 07:07 PM
  2. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 08:29 PM
  3. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 09:00 AM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 02:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-07-2007, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
