Page 12 of 12 FirstFirst ... 29101112
Results 111 to 120 of 120
  1. #111
    Platinum Member rbarker's Avatar
    Join Date
    Jul 2003
    Posts
    815
    Massachusetts
    BX 25
    Default
    Quote Originally Posted by bx2360 View Post
    It was prefab did'nt get door on end, had to get folding Rops for a Bx25 did'nt realize when I ordered it a Amish style roof is a little shorter than a A frame roof but I do have more loft space. Floor is built like a house with 16" floor joist 5/8 plywood on those and 5 4x4 post running the whole length of it to rest on blocks.Just cleared out some pine trees and cut stumps down to ground level.If you can go bigger than you plan you can always use the extra space I was gonna get a 14x28 and glad I went 32!!!!
    Thanks for the details. Unfortunately my Rops folds but the cab does not so I need a door taller than the standard size. I can't really go bigger than 10x20 but it will be going over an old pavement area so that should work pretty good. I'm definitely looking at prefab since I don't have the time to build it myself and I'm not as young and strong as I used to be.
    Sent from my iPad using TractorByNet
    Bob B.
    Kubota BX25, FEL, 60" MMM, Curtis cab with heat
    Kubota BX2750D snow blower, 5' Estate rake, 5' rear blade
  2. #112
    Platinum Member NHmitch's Avatar
    Join Date
    Mar 2012
    Posts
    765
    SW New Hampshire
    Bolens G154/IsekiTX1300F
    Default Re: Does your tractor stay in or outside?
    We live in New Hampshire, just over the boarder, and we ordered our 5 stall, 12X54 barn from a company in Maine called Hill View mini barns. We never actually went there, but we looked at a lot of barn, and shed companies in Mass, NH, VT, and ME. Hill View had the best prices by far, and they worked with us, since at the time, they had never ordered a shed row barn from the amish that large. They worked with us to custom build it to the exact specifications, and it was still cheaper than anywhere else, and cheaper than anyone would build it for. There link is: Storage Sheds, Garages, Camps, Horse Barns- Hill View Mini Barns
    This is our barn when it was delivered a few years ago. The discolored base is not part of the barn. Its rough cut 6x6's that I had used to maintain the base when it was delivered. It was made by the Amish in PA, and trucked up on a semi as one piece. It is a great structure, and very well built..Does your tractor stay in or outside?-photo.jpg
    Quote Originally Posted by rbarker View Post
    Mitch
  3. #113
    Join Date
    Mar 2012
    Posts
    765
    SW New Hampshire
    Not sure why this posted sideways?
    Click image for larger version.
    Mitch
  4. #114
    Join Date
    Jul 2003
    Posts
    815
    Massachusetts
    BX 25
    Default
    Quote Originally Posted by NHmitch View Post
    Thanks for the link! This is exactly what I was looking for and the prices do appear much cheaper than other sites I've looked at. It looks like a really well built building and I've had a good experience with Amish built buildings before. My gazebo is a prefab Amish built building and the workmanship and materials are superior to those available locally.
    Bob B.
  5. #115
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    2,781
    Nova Scotia
    Kubota L3400DT
    My Kubota sleeps indoors most nights. On winter weekends it gets to sleep under the stars once in a while if I'm clearing snow and don't want to spend time Saturday cleaning it off before parking it inside.
    Sean
  6. #116
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,026
    texas
    kubota M7040 &m7040
    Does your tractor stay in or outside?-barnpic2.jpg New one always inside,the old one already faded so if I have room it does(fourth stall not in picture)..
  7. #117
    New Member
    Join Date
    Jan 2013
    Posts
    1
    New Richland, MN
    1952 8N Ford Tractor
    I Keep my tractor in a large round style portable shelter. Seems to work out fine. I have been doing it this way for a couple of years now. Here is a link to their website Northstarcanopy.com.
  8. #118
    Platinum Member Firefighter Kubota's Avatar
    Join Date
    Aug 2008
    Posts
    573
    Seacoast NH
    Kubota 7510
    Shelter logic 12 x 24 x 10'tall. ... on 3/4 gravel base... wanted to be able to get my fullsize truck w/ lumber rack in there if needed
    Biggest issue is chasing mice nest out from under the dash or on the block... I check regularly...
    After 5 years the tarp is just barely showing its age with a few pin holes etc... Maybe another year and I'll replace it.. best $700 I spent..
    Does your tractor stay in or outside?-picture-074.jpgDoes your tractor stay in or outside?-picture-138.jpg
    B 7510
    FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, AND A CUP HOLDER!
    IAFF L-2892
  9. #119
    Gold Member BuzzardA91's Avatar
    Join Date
    Jul 2012
    Posts
    318
    West Granby CT
    JD 4105. 375 Backhoe. 2005 Polaris Ranger
    Wife gets one bay and I park tractor in other. My truck stays outside and suffers for it. Oh well...
  10. #120
    Join Date
    Mar 2009
    Posts
    66
    canada
    kubota b2920
    My tractor is in unheated garage ,I have a block heater but haven't used it yet,I live in ontario canada, I do put fuel additive to prevent fuel freeze up,the temp in garage is aprox 0 c or 32f and can drop to -5 Celsius on cold nights,but tractor never failed starting 5 seconds glow plugs on and away it goes.
Similar Threads
  1. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 08:29 PM
  2. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 09:00 AM
  3. Replies: 55
    Last Post: 11-17-2009, 08:16 PM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 02:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-07-2007, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
