Page 3 of 12 FirstFirst 123456 ... LastLast
Results 21 to 30 of 120
  1. #21
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,643
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default
    Everything outside, no block heaters but diesel treatment year round.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  2. #22
    Banned
    Join Date
    Nov 2012
    Posts
    109
    east coast
    deere,kubota,case,sears,new holland, Mf
    Default Re: Does your tractor stay in or outside?
    I never used diesel treatment in my life and all my old machines always ran fine. Even the old D8 cats we used at the landfill back in the late 60's and early 70's never got so-called diesel treatment. Fired right up in the cold mornings. Diesel treatment is just another way for monkey to make money. i have some old machines now that still fire up with dirty old stale fuel. I hope you guys dont buy those other pep boys products like "Mechanics in a bottle" haha
  3. #23
    Bronze Member PandDLong's Avatar
    Join Date
    Apr 2012
    Posts
    75
    Southern Alberta
    Kubota L3540
    OUtside baking in the sun during the summer wherever it's convenient to leave it.
    But come winter, into an enclosed shed it goes so I can hook up the block heater and keep it out of the worst of the weather - snow and wind. Temperature can drop to -40 and - unlucky for me - I often need to use it for snow clearing or moving hay bales when it is colder than -20. No diesel additives. Once the block heater is plugged in, no problems starting just a long time to get the hydraulic oil warm enough to operate!
  4. #24
    Platinum Member NHmitch's Avatar
    Join Date
    Mar 2012
    Posts
    762
    SW New Hampshire
    Bolens G154/IsekiTX1300F
    I keep mine inside an unheated outbuilding near the barn. It shares the building with implements, a farm purposed 4 wheeler, and extra hay that is overflow from two other hay barns. I have to use the tractor almost every day to haul shavings, hay, and manure. Most of my neighbors have tractors, and the ones that sit outside 24/7 look about 10 years older than they are, but looks usually don't effect how they run. I have seen rust buckets fire right up and work all day, but I prefer to keep mine in as new of condition as I can for a 30+ year old machine mainly because I cannot afford to replace it, and it is very valuable to me. I do keep a trickle charge on the battery, and with the glow plugs, it fires right up. I use Bio-Kleen, but mainly to prevent microbial growth, bacteria, and fungus from entering my fuel lines, and filter.
    Mitch
  5. #25
    Join Date
    Dec 2001
    Posts
    232
    Lebanon, Tennessee
    JD 5055D, JD 790 MFWD
    Mine sits outside. Has a canopy over the operators stations. Sometimes it can dip into the single digits here in Middle Tennessee, but when it is that cold, you won't find my rump in the drivers seat, anyways. No fuel treatment, has always started up with glow plugs.
    Dave
    John Deere 5055D/ FEL/ Root Grapple & MX7 Brush Cutter
    John Deere 855D Gator
    John Deere 790 (30 HP version)
    John Deere 757
    John Deere 325
    John Deere HD45
    John Deere 140
    John Deere 68
    Power House Prowler/HD trailer and all the attachments
  6. #26
    Join Date
    May 2012
    Posts
    2,238
    Knoxville, TN
    Bobcat CT225
    Inside, in a pole barn. Keeping it out of the sun is my main motivation. UV will do a number on things. If I am in the middle of a project where I am using it, I often won't bother to park it in the barn at the end of the day. I don't baby it. But there are quite a few weeks when I won't use it at all, and I figure it's dumb to just leave it sitting out in the weather getting wear for no good reason.
  7. #27
    Banned
    Join Date
    Dec 2011
    Posts
    1,129
    L5450
    Default
    Inside with a degree of protection (roof leaks a little).
  8. #28
    Join Date
    Mar 2003
    Posts
    693
    Maine
    Kubota B2620
    Always use diesel treatment (all seasons) and keep tractor in garage that can be heated to melt off ice and snow after use. All attachments kept inside.
  9. #29
    New Member
    Join Date
    Oct 2012
    Posts
    20
    owasso,ok
    kubota m6800dt
    I keep mine inside my cinderblock but unheated horse barn. No heater block or deisel treatment and no problems starting. Myself on the other hand is a little slow to get started in extreme cold.
  10. #30
    Silver Member vabiker23518's Avatar
    Join Date
    Nov 2010
    Posts
    207
    Keysville, VA
    TM233
    Mine sits under the covered back porch with a tarp. So its out of the sun and rain but in the ambient temp which can range from 10 F to 100F here in Virginia. One day I'll get a garage for it!
Similar Threads
  1. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 08:29 PM
  2. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 09:00 AM
  3. Replies: 55
    Last Post: 11-17-2009, 08:16 PM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 02:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-07-2007, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
