Page 4 of 12 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 120
  1. #31
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,947
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Does your tractor stay in or outside?
    Inside unheated barns and sheds, rarely below zero around here and mostly not even below 20's.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  2. #32
    Veteran Member Lou66's Avatar
    Join Date
    Nov 2012
    Posts
    1,390
    Brazoria county where Texas began
    Deere 990/Montana 5740
    I live in texas along the gulf coast.. we don't worry about cold weather to much,, maybe light freeze once or twice a year.. I keep my tractors and balers inside,, cutters outside they have covers over the blades,, rakes outside, C-580 backhoe/loader outside,, most of small equipment is kept in the barn.. like tillers, plows, disc, boxblakes, grades blade and few other pieces.. Lou
    "Life is good if beer is cold"
  3. #33
    Veteran Member smfcpacfp's Avatar
    Join Date
    Nov 2007
    Posts
    1,346
    Sands Township, Marquette Co, Michigan
    Kubota B3030HSDC
    In a pole building with the rest of my equipment.
  4. #34
    Super Member
    Join Date
    Apr 2000
    Posts
    8,408
    Shingle Springs California
    New Holland TC40D
    That was my thinking too. Sun/UV can do a job on expensive tires, hydraulic hoses etc. And, I have some other stuff(canoe, beer brew stand etc)
    Quote Originally Posted by joshuabardwell View Post
    Inside, in a pole barn. Keeping it out of the sun is my main motivation. UV will do a number on things.
    RobertN in Shingle Springs Calif
  5. #35
    Join Date
    Sep 2010
    Posts
    244
    Central Maine
    Kubota BX25
    It's in the new garage. Before that it was in a tarped shelter. I use fuel treatment in the winter and while it has a block heater I have only used it twice. I am in central Maine so it can get cold here, but with a little glow plug warming it starts right up.
    Proofread carefully to see if you any words out.
    BX25, BX2750D Snowblower, Bro-Tek thumb, BXpanded Forks and Under Armor, Ballast Box, 3-PT Pallet Forks ...... My Kubota Pics
  6. #36
    Gold Member StrangeRanger's Avatar
    Join Date
    Feb 2007
    Posts
    364
    Northern VT
    L3400 HST
    Thanks all. I was just wondering cuz my L3400 had a front tire roll off the rim on me yesterday and I left it sitting where it was. It was awfully nice parking my sons' ATV and other stuff in what is normally the tractor's spot in the garage and I almost considered letting it stay outside. But it's bad enough here in northern VT to have to go out and start it in the cold garage, I don't think I'd like having to clear the snow off or uncover it etc. Guess it will go back in the garage when I get the tire fixed. Boy was that a pisser.
    j
    j
    L3400 HST, LA 463 FEL, 6' Woods blade, 65" Woods box blade, 60" Meteor blower, CCM top & side links, 2 extra rear remotes waiting for a use and a big, fuzzy hat
  7. #37
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Inside all nice and dry and warm.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  8. #38
    New Member tcfarm's Avatar
    Join Date
    Jan 2012
    Posts
    16
    se south dakota
    kubota l3430
    my 3430 has never spent a night outside since I got it three years ago.
    Travis
    2006 CTD
    2006 kubota L3430
    2009 Teryx
    1983 JD 420
  9. #39
    Veteran Member tungularafishcamp's Avatar
    Join Date
    Sep 2010
    Posts
    1,584
    kodiak island, Alaska
    kubota L2800, 1/2 of a L48
    Quote Originally Posted by dsmiley View Post
    Mine has started as cold as -35 without using the block heater but I am sure it didnt do it any good. Any time it is below 20 I plug it in a couple hours before I start it when possible, lot quicker start/warm up that way and initial idle is not so rough/harsh sounding.
    If you have a place to put it inside by all means do it, I built my new gearshed oversized just so the tractor would have a home.
    Rick
  10. #40
    Gold Member Ace3's Avatar
    Join Date
    Jan 2008
    Posts
    257
    Albany, New York
    Kubota L3540 Cab
    In a pole barn, yes to fuel treatment and also a block heater.
Similar Threads
  1. Replies: 67
    Last Post: 04-02-2014, 07:07 PM
  2. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 08:29 PM
  3. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 09:00 AM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 02:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-07-2007, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
