Page 9 of 12 FirstFirst ... 6789101112 LastLast
Results 81 to 90 of 120
  1. #81
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,146
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Does your tractor stay in or outside?
    Quote Originally Posted by Trails End View Post
    Just finished a 12'x16' car port for the tractor and attachments, attached to my existing garage.
    Also finished the dollies for the attachments.Attachment 292535
    very nice attached carport. So what is on top of the rohn 25 tower in the background
    James k0ua
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #82
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Default
    Inside an unheated pole building. one has power the other dosnt. still better than outside
  3. #83
    Super Member 300UGUY's Avatar
    Join Date
    Apr 2004
    Posts
    5,402
    Howell, Michigan
    Kubota L3400, Farmall H
    My L3400 is in a unheated pole barn. I do have a concrete floor and power. I hope to heat and insulate it in a year or so.
  4. #84
    Gold Member Trails End's Avatar
    Join Date
    Jul 2012
    Posts
    315
    Candia, NH
    Bobcat CT335
    Quote Originally Posted by k0ua View Post
    James k0ua
    Thanks, James! It's a Tennadyne 6 element log periodic and the tower is a 58' Rohn 25 fold-over. Call is K1HJC.
    Best Regards from Candia, NH
    Bobcat CT335, 8TL FEL with 68" bucket, EverythingAttachments 72" boxblade
    Bobcat 72" Snow blade, WR Long OBG2-48 Grapple, Pronovost Puma-74 snowblower
    Everything Attachments ETA-CMP-LR-84 Landscape Rake
  5. #85
    Join Date
    Jun 2009
    Posts
    28,146
    Branson, Mo.
    Ha, I figured, as much!.. I have a little MA5B on mine at 40 foot. and a Windom slung off of it. It is a Tilt over, homemade brackets and all. But it works for me.
    73
    James K0UA
    James K0UA
  6. #86
    New Member
    Join Date
    Dec 2012
    Posts
    23
    Ga
    Ford 8N
    My 8N has sat outside for at least the past 25 years. If it's going to be parked for an extended period it gets a tarp over it. Otherwise just flip the seat over backwards. Of course, it's just an ugly old farm tractor that gets run through the woods every now and then.
  7. #87
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Default
    Quote Originally Posted by spotco2 View Post
    With any luck that tractor last another 25 years. Maybe a lot more.
  8. #88
    Join Date
    Mar 2002
    Posts
    581
    Western MA
    Kubota BX22
    When not used my tractor stays in a heated garage with thermostat set to 40 degrees F. All my implements are inside too.
  9. #89
    Member Mystro's Avatar
    Join Date
    Aug 2012
    Posts
    41
    PA
    BX1860
    As long as you have power to plug in a Battery Tender Jr and a roof, your tractor should have all it needs.
  10. #90
    New Member
    Join Date
    Dec 2012
    Posts
    7
    Sault Ste. Marie, Ontario
    Allis Chalmers B, International 434
    I keep my Allis B project in the garage, right now behind the 3/4 project. I hand crank it and it always starts fine. My International 434 Diesel stays outside for the most part. It gets fairly cold quite often up here, down to -20 degrees celcius and lower quite often. It will usually start with the glow plugs and a few minutes work, but we usually use the block heater, its way easier. My soon to be John Deere 50 and 8N ford (as soon as grandparents decide to move to town), have been outside since at least the mid 70's, a few issues, like the distributor filling with water once a short while ago, but they almost always have started. Recently the Deere has been inside for the winter and it starts way easier in the cold.
Similar Threads
  1. Replies: 67
    Last Post: 04-02-2014, 07:07 PM
  2. Buying Advice Should I stay away from a used Montana Tractor?
    By Patrickmtrs in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2011, 08:29 PM
  3. JD 755 compact tractor won't stay running
    By DouglP in forum John Deere Owning/Operating
    Last Post: 02-03-2011, 09:00 AM
  4. Backhoe Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Attachments
    Last Post: 07-15-2007, 02:59 PM
  5. Buying a backhoe for tractor any brands to stay away from?
    By Baranx4 in forum Buying/Pricing/Comparisons
    Last Post: 07-07-2007, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
