Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Veteran Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,203
    MA
    L5450 Cab, L48, L3250, L345DT
    Default Re: L4850 with LA950a loader - does not go very high
    Clint - I measured the loader cylinders on my LA1150. Boom cyls are 3" o.d. but length is the same 24" from the notch like yours. The bucket cyls look same stroke except they are not notched (round all the way).
    This is a head scratcher. The only long shot thing I can think of is one of your boom cylinders has the wrong gland parts in it, keeping it from extending out all the way. Does the frame seem to twist a little when it hits the limit going up? Is one cylinder stopping it or do they both max out at the same point?
    LeeJohn - the Craigslist loader is an LA650 - designed for a smaller tractor.
    L5450, L48, L3250, L345, never enough attachments
  2. #12
    Join Date
    Sep 2007
    Posts
    1,382
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Well that would make a differents. There went the air out of my sails.
  3. #13
    Join Date
    Sep 2007
    Posts
    1,382
    Doniphan, Mo.
    Maybe not go back and look at your pic in post 3. The pin is alot further from the bend then his is. See what you think.
  4. #14
    Join Date
    May 2000
    Posts
    2,203
    MA
    I have the brochure for the L4850 and L5450 tractors that also describes the LA950 and LA1150 loaders. I believe the LA950 and LA1150 are identical except LA950 cylinders are 2-1/4" bore, and the LA1150 has 2-1/2" bores (20% more area, 20% higher forces) There is a paragraph that talks about both loaders being fast and states the bucket goes up over 9 feet. There is no clue that the LA950 has different range of motion.
    I'm still thinking the problem may be one of the boom cylinders.
    Did you think there's a difference in the loader pins? which one(s)?
    Attached Files Attached Files
  5. #15
    Join Date
    Sep 2007
    Posts
    1,382
    Doniphan, Mo.
    The first one and the upper pin or piston end of cyl.
  6. #16
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    With Thanksgiving prep, etc. I forgot to go measure the front cylinders. Having studied the pictures the Kubota Loader on craigslist (lifting very high) is clearly a different loader - maybe LA650 - I can't read it, but it does have different geometry. It does look like the front forks stick out a little more on the smaller loader, which I expect reduces the breakout/lifting.
    My main cylinders measure 24" , when fully extended there is 21.5" of steel (shiny) rod that sticks out... That means that there is 2.5" of endcaps, seals etc in the cylinder - which seems about right to me, although another 1" would probably make a significant difference.
    I didn't measure but I can just barely stand under the bucket when its up - so its about 6' with the bucket level. Its really interesting that the brochure mentions 9' - am definitely not getting 9'.
  7. #17
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    Dick, I just found the spec sheet you posted on a much older post somewhere. It lists the loader cylinder piston stroke at 21.65" so I am getting full lift out of the cylinders. What I did notice is that your front tires are significantly larger than mine, which would increase the height and the angle. So I guess its working as it should.
    Thanks again,
    clint
  8. #18
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    A friend at work just made a discovery... It looks like the lower cylinder pin on my loader is into an asymmetrical bracket welded to the uprights. In the pictures of other loaders it look like that bracket is symmetrical and possibly a little higher. It seems possible that when my unit was welded it was put a little lower... an inch would probably make a big difference.
    Dick, when you get a chance can you please measure the pin distance from the main loader pivot to the lower cylinder pin - see picture
    I will check mine this afternoon..
    Thank you,
    clint
    Attached Thumbnails Attached Thumbnails L4850 with LA950a loader - does not go very high-img_1128.jpg
  9. #19
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    haha - sorry wrong pic. L4850 with LA950a loader - does not go very high-img_1440.jpg
  10. #20
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,796
    Canada
    B3200, L5740,
    If you look at your main lift cylinders with the bucket on the ground they are extended out farther than they should be. You have the wrong cylinders. You should only have about an inch of extended cylinder with bucket on the ground.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
Similar Threads
  1. L4850 value?
    By 2000silverz28 in forum Kubota Buying/Pricing
    Last Post: 06-07-2012, 03:24 PM
  2. L4850, BF900
    By Keltic in forum Kubota Owning/Operating
    Last Post: 01-06-2012, 10:16 AM
  3. Loader Kubota LA950A loader weak
    By ussofa in forum Kubota Owning/Operating
    Last Post: 05-12-2010, 09:28 AM
  4. Need reasonably high hp tractor w/cab & loader...
    By Dargo in forum Owning/Operating
    Last Post: 05-15-2006, 03:20 AM
  5. Skid loader pedals lock under high rpms
    By TeXXXas in forum New Holland Owning/Operating
    Last Post: 09-14-2004, 03:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
